585,752 active members*
4,499 visitors online*
Results 1 to 9 of 9
    Jan 2007
    161
    fixture offset Z values
    Hello,
    I am wondering why this seems backwards to me. Here is my issue. I touch all of my tools off of the top of the hard jaw and want to shift my work coordinate Z to the top of my part instead of the jaws. Currently I need to adjust the Z-1.25 to go UP to the top of my part, not Z+1.25. If I put +1.25 in the Z offset I will have a crash situation. Why is this backwards? The machine I am working on is a mid 90"s DC servo machine.
    _____________
    teamjnz
    Nov 2005
    28
    Re: fixture offset Z values
    Work Shift, Shifting the WORK DOWN in the Negative direction, NOT the Tools
    Jan 2007
    161
    That is correct! But not in this case or on this machine. I am shifting down to make it go up... That is backwards.
    _____________
    teamjnz
    Dec 2010
    1230
    Does your G52 read a negative or positive Z number for your offset? I have the wips probe so I know my tool values are way different, but my Z in G54... Is always a negative. Typing "-0.003" into G54 offset screen will cut 0.003 DEEPER into the part.
    Brian
    WOT Designs
    Feb 2015
    174
    Sample of the code please. I'm lost. G43 as apposed to G44? Using the common is dangerous. I really don't understand.
    Nov 2007
    1702
    On a 1994 machine, the settings may be more basic than what I'm used to, so I can't point you to a specific number. Page through the settings pages and look at each one. There are a couple in there that handle how it deals with offset values and entered numbers. I'd bet one of those was changed by somebody.
    Greg
    Nov 2006
    490
    Second Donkey. It depends on the vintage of the machine, but *most* of them can be changed to follow the cartesian convention. Only the super mega old VFs cannot be set correctly and must be "opposite" of what you want. If you end up with one of those machines, it's basically backwards of the common cartesian system (think of the table moving instead of the tool moving...for work offsets only).
    Check parameter number 57, there's a bit called "negative work offset" which you want to be "1".
    Jan 2007
    161
    Hey Guys... I just looked at the fixture offsets and realized with Ydna's post that my fixture offset values are all positive in my 94 machine. I looked at my 96 machine and all of the fixture offsets are negative. I am surprised I never noticed this. My 96 machine has the negative work offset parameter set to 1 and the 94 is set to 0. I will be changing this once I complete the current job in the machine.
    High 5 Ydna!! Thanks for your your response.
    _____________
    teamjnz
    Jul 2004
    100
    JNZ,
    When you make that change, watch your old programs on that machine. You may have to reverse the sign on all the Z positions!
    Regards, Ray
  1. Gcode to set offset values
    By mioduz in forum Tormach Personal CNC Mill
    Last Post: 05-16-2014, 09:28 PM
  2. Reading offset values
    By crazycnc in forum Fanuc
    Last Post: 01-27-2011, 09:49 PM
  3. Are lathe offset values on radius or diameter?
    By sinha_nsit in forum Fanuc
    Last Post: 11-06-2009, 03:46 PM
  4. Offset values get changed
    By sab in forum Uncategorised MetalWorking Machines
    Last Post: 06-28-2007, 05:42 AM
  5. wire offset values
    By Stevatome in forum Fanuc
    Last Post: 03-09-2007, 02:42 PM
