Originally Posted by
john-100
Hi
I've not looked at all the Gecko servo driver manuals but the one I looked at random indicates terminal 5 is at 0V when a fault is detected
what driver are you using ? and what power supply are you using ?
unless you have a fault detector / E stop circuit inter- connecting all your servo driver error outputs
I'm assuming you are using a switch mode power supply ,
I suspect the "tick" noise you hear is from the power supply
a momentary loss of power could cause all drives to fault - the manual should say what the LEDs indicate
John
PS
how are you controlling the servo drivers ?
1 , using a PC printer port and Breakout Board - what board ?
with some BOB's the step & direction signals pass through an octal buffer
the loss of the enable signal to a buffer IC will stop 4 axis at once
or 2 , a motion controller like the smooth stepper ?
