I have just begun to use the Hoss Tool Probe screen and I am trying to do something with it I have not yet figured out. I am mounting images to Plexiglas and then using the CNC to cut out the image. My images will have an X-Y registration dividing the image and centering it. My intent is to build a tool to add in registration. The tool will look like a small framing square with a circle cut out centered on the inner edges. Once I have aligned the tool with the registration marks I can use center finder to locate the center of the image. I will move several inches down the X axis and use the edge finder to locate the edge at that point. The delta between 0,0 and the new edge location will let me figure the rotational misalignment so I can enter a G68 code. However the edge finder resets to zero rather than giving me the delta. Is there any way to prevent it from zeroing the axis?
Rich
