585,902 active members*
4,282 visitors online*
Page 3 of 5 12345
Results 41 to 60 of 84
  1. #41
    Mar 2015
    40
    Re: My SH-350 has landed !!!
    Quote Originally Posted by bratan View Post
    Also I have another question about 350 machine. Does any of yours have some kind of smoke management framework inside the machine? I.e. from cutting table to exhaust on the back? I build a very powerful fume extractor, but it still stinks bad when I cut acrylic It could be fault in my extractor, but I suspect smoke might be also leaking thru machine itself.
    leak is unlikely - with powerful (how poerful BTW? ) smoke extraction there will be lower pressure inside the machine and there be inflow of air through all the pssible openings. for leaks i would check the high pressure side of your fan
    with that acrylic will outgass for sometime after being cut and that will smell. i run a DIY smoe extractor built around blower fan from household HVAC, huge amounts of airflow even with the restriction of being drawn through 14x24 box with 6" of activated carbon in it . i usually let the machine vent for at least 10 seconds after the job finished before i open the lid, and the acrylic wil still smell. lasermark material will smell even longer.
  2. #42
    Jan 2015
    62
    Quote Originally Posted by agrasyuk View Post
    I build this "instructables" extractor. It uses 392 CFM centrifugal fan. I discovered it leaks somewhere near top of the filter, but can't figure out why. Added some more sealing, fan is sealed good with caulk. I think smell is passing thru top layer of carbon somehow... And not just acrylic, even smell from burning wood seeps thru like there's no filter there....
    I might try different design, i.e. box shape...
  3. #43
    Mar 2015
    40
    i seen this solution and didn't go for it , one reson is the fan itself. maybe i'm over the top conservative about it but 400CFM is IMHO not enough and that rating is before any kind of flow restriction. I don't have math calculations to back my doubt, but i think this solution also does not hold enough carbon for the job
    . if there isindeed no leaks i wonder if environment you workin in has to do with this. as i found my scrubber works extremely poor when temps are below freezing (i work in unheated garage). my theory behind is moisture trapped on carbon (its quite humid at my place) freezes and blocks any gas adsobtion. i exhaust outside and it smelled very bad working during this winter. now when above freezing temps are here there is no smell outside at all, just the outgaing when i lift the lid.
  4. #44
    Jan 2015
    62
    I'm going to take reading on air flow with my anemometer tonight and post results.As for carbon, I think it actually took more than needed. I ordered 55 lb and used 3/4 of it (probably at least 30 lb)...
    Interesting about temperature, it's actually very cold in my basement (around 50F) but not humid...
    If I don't get this working I'll have to vent outside. Fortunately I have window near cutter. Unfortunately it swing out glass type, so I need to figure out how to fix and position 6" duct in it...
  5. #45
    Aug 2014
    111
    Works fine. Different machine but same idea.
    https://docs.google.com/file/d/0ByJi...p=docslist_api
    Another side two computer fan blowing.
  6. #46
    Jan 2015
    62
    Quote Originally Posted by miketola View Post
    Nice! You got same fan as I! Not sure I want/can drill thru solid foundation of concrete tho
    Good idea with fans btw. Question, are you using epoxy to hold those pins?
  7. #47
    Aug 2014
    111
    Yes it,s epoxy. Used many many hours. No problem.
  8. #48
    Jan 2015
    62
    Took some wind measurements. When filter not attached to laser cutter I get 1074 ft/min or 336 CFM (if my calculations correct). With everything attached to laser cutter I get about 210 CFM inside.
    I'm planning to take a duct tape and seal top 2-3 inches of the ring holding activated carbon and also attach extension pipe to the motor so it seats deeper inside pre-filter. Other than that, I'm out of ideas
  9. #49
    Mar 2015
    40
    your construction looks really clean and well done. i see foam sealing strips on the edges, i assume motor to plate is also properly insulated. to me it seems very unlikely that you could have gotten a batch of bad carbon. so the only question that remains is whether the thikness of of carbon that you have is sufficient for the job. i read somewhere it should be 5-6", 4" at the least, but can't find it.
    again, i don't have any academic way to prove it , nor i had personal experience with this exact construction, but as i see it the carbon will get compacted under its own weight and more air will pass through upper layers due to less flow restriction, which means not all your carbon load is participating in filtering effort equaly. does it really matter i don't know, but thats why i desided to go for a vertical airflow for my filter.
    ADD:
    will repost picture of my solution here as well (front panel removed, carbon container empty, changed machines since)
  10. #50
    Jan 2015
    62
    Thanks for posting picture btw!
    I added some "Gorilla" duct tape to the top rim of the outer cage filter and it helped a lot! There's a very little smell now coming from the filter, it's virtually gone. I think you right about carbon getting compacted, this is not a good design...
  11. #51
    Jan 2015
    23
    glad to hear you resolved the mistery.
    I am thinking about the carbon get compacted by weight and so: what about divide the 6" filter in 3 filter of 2"? could this help to keep the flow steady and the filtering effect efficient?
  12. #52
    Jan 2015
    62
    I posted a DIY on my site, how to make pin bed. It was super easy btw, and cost me about $60.
    Now I'm trying to figure out settings for different materials. If everyone can share theirs it would be awesome. Plywood is real tricky. I got few different kinds from Lowes and 1/4" white birch plywood almost doesn't cut at all. I managed to do partial cuts at full power and 3 mm/s speed but it caught fire in the process.
    5.2mm lauan plywood cuts great, but I just tried some 1/4" solid oak and I was shocked that it get's sliced like butter at 5 mm/s at just 25% power!
  13. #53
    Aug 2014
    111
    Good work. Almost same as mine pin table :-)
    I think pin table is best of all tables.
    Only if you make alot of small parts and they drop down and laser beam burn it when it cut next one.
    I have 40w laser and i cut 4mm birch plywood 23 % power and 10mms. 3mm acryl 26% power and 10mms. 4 mm acryl 48% and 10mms. 3 mm HDF 27% and 10mms.
  14. #54
    Mar 2015
    40
    interesting. it looks like i'm getting nothing close as far as power from my 800mm tube compared to you guys. to cleanly cut 2.5mm acryl i use 12-14mm/sec at 75% power. for 6mm i use 8mm/sec and do 2 passes at 75%. 75% power transalates into 16mA and i don't go over that. what is the actual thikness of your 3 and 4mm sheet in inches?
    if you getting such good preformance "5 mm/s at just 25% power" why not increase speed (and power) for better finish ? it seems like you have plenty in reserve.
  15. #55
    Jan 2015
    62
    I'll have to check what settings I used with my 2.4mm arcylic...
    I actually tried increasing speed, but power requirements jumps drastically. At 8 mm/s I had to use 60%, and at 15 mm/s it went almost to 95%. I actually don't see much difference in cut quality between 5 mm/s and 15 so I decided to use lower speed with lower power. I'm very new to laser cutters, so I'm still figuring out when it's better to use faster speed with higher power, etc...
  16. #56
    Aug 2014
    111
    There is alot of different plywoods on market. In finland we have good guality birch plywood. It depends what glue they use. If you buy "wrong" plywood you can,t cut it. It just burn black and smoking. Poplar is soften than birch etc. Because of my lens dof is only 7mm, so it,s max what i can cut.
  17. #57
    Aug 2014
    111
    Bratan. Are you aure your focal lenght is correct?
  18. #58
    Jan 2015
    62
    Yes I'm pretty sure. I found it draws thinnest line at 19mm from the end of the nozzle (lens is actually higher). To cut I lower nozzle by 1/2 of material thickness. I made a "jig" tool from acrylic to calibrate height for different materials. My z-table is not 100% level tho, I spend a lot of time adjusting it (after I removed timing belt), but it still a mm or two off in some corners.
  19. #59
    Aug 2014
    111
    Ok. I have different machine but focal lenght and dot size and dof you can calculate them. I cut max 6 mm material. Quality is important to me. I need small dot and good engraving quality. Also its important to cut easily. My table is now good and i cut all 4mm to thin paper with same settings easily. I dont use any acryl measurement stick. I watch quality and cutting power. If you think your focal is now ok. Take plywood and put power like it just almost cut it. Then lift table 1 mm and test and 2 mm and test. Then put table down 1mm and test etc. Last check your plywood and best cutting quality. 1-2 mm wrong and its means. What lens there is ? 2" 2.5" ?
  20. #60
    Jan 2015
    62
    Thanks, I'll try that. I have no idea what kind of lens I have, but I suspect it 1.5". I never measured focal distance directly from the lens...
    Different subject, does anyone know how much water is ideal to cool laser tube? I'm currently using 2 gallons (7.6 liters)... I'm planning to get cylindrical aquarium and use it as water container, wondering what capacity should be...
Page 3 of 5 12345
