585,981 active members*
4,151 visitors online*
Results 1 to 13 of 13
    Aug 2006
    14
    Bridge rectifier go poof
    What did I do wrong? I hooked the ac input to the 2 posts not marked with the positive and negative. As soon as I applied power I got the magic smoke.
    I'm using a 28v toroidal transformer and a 35amp 1000v bridge rectifier. I measure the voltage from the transformer and it was 29 volts.
    Bobby
    24221
    You sure they were on opposite corners, not adjacent posts?
    Is the bridge shorted now? was just a capacitor hooked up to the DC side or?
    Al.
    Albert E.
    Oct 2004
    727
    Quote Originally Posted by blfinche View Post
    Bobby
    Bobby,
    Those markings are not Positive (+) and Negative (-), they are Positive (+) and AC (~). If I remember correctly, the matched connectors are oriented diagonally. See Wikipedia's explanation of the Diode Bridge (with pictures). Note the diagram with the AC Input, DC Output and Load labels in the section devoted to Output Smoothing. Be sure to verify proper connections by tracking down the "Data Sheet" for the bridge rectifier (and other components) you're using. Can't find the right Data Sheet, contact the company you purchased the component(s) from, they should be able to provide it or direct you to the link on the manufacturer's web site.
    I see another bridge rectifier in your future. Be careful with bridge rectifiers, a lesser known name for them is "bridge rectal-fryer". Make sure you take precautions so that you don't find out why... the hard way. :rainfro:
    HayTay
    Don't be the one that stands in the way of your success!
    May 2004
    198
    Bobby
    Bobby,
    Look closely at the "minus" sign. I'll bet it is a wavy line signalling AC. I've attached a PDF and a JPEG that shows the rectifier "pinouts". It is a sectional cut from the package wiring diagram included in the package.
    Hope this helps!
    Attached Files Attached Files
    Sep 2006
    6463
    Hi blfinche, one of the golden rules before connecting up any electrical 'quiptment is to check the resistance of the connection point.
    This means that if the resistance is low then either a dead short exist or you've got the wrong set of contact points.
    If you don't test the connection then just putting the plug in will result in a heavy current flow and goodbye anything that is in the line, diodes, transformer or worse a fire in the cables.
    I would have thought you would have had a fuse in the output of the bridge rectifier/voltage regulator.
    Moral:- Don't go blindly in where.........
    Ian.
    Aug 2006
    14
    I think I have it. I did not connect diagonally. I thought the ~ was a negative sign. So I should connect to the ~ and the corner diagonal to that?
    Bobby
    24221
    Quote Originally Posted by handlewanker View Post
    The problem with checking a semiconductor on the normal resistance range on a modern meter is that it will not show conduction due to not enough voltage to forward bias the device, so it shows high resistance, you would need to have a meter with a diode check range.
    Bobby, the AC connections on a bridge are the ~ signs, and generally are on opposing corners, but adjacent posts cause a short.
    Al.
    Albert E.
    May 2006
    2420
    Yup you have it now Bobby, connect the AC to the ~ and the diag opposite corner, the DC goes positive on the + side and the negative is on the diagonally opposite corner.
    The way you had it originally meant that there was a dead short across your transformer secondary on one half of the wave, usually the weakest part gives way, in this case sounds like the rectifier, hopefully it didn't damage the transformer, check your voltages once you have it correctly wired, and might not hurt to put a fuse in the circuit.
    Good luck.
    Russell.
    Nov 2020
    Re: Bridge rectifier go poof
    Hey so just stumbled across this thread. Very interesting .. I am having a bit of trouble understanding how a bridge rectifier work though. Is it just a bunch of diodes?
    Dec 2020
    Hey Jacob,
    I can certainly help. So a Bridge Rectifier is an assortment of diodes its usually 3 or more and its used to convert AC to DC current.
    Hope that helps..
    Nov 2020
    Ok I understand .. anything else important I should know about them , so that I can understand them more in depth or is that about it ?
    Dec 2020
    Quote Originally Posted by jacobgoona View Post
    Yea of course .. there is always more. SO essentially as mentioned before it is an assortment / configuration of a bunch of diodes. it allows current to flow in one direction and not backwards. Also AC current converts to DC. These are generally used in power supplies , battery chargers etc..
    There are a lot of different types of rectifiers , not just a bridge rectifier. There is a Full wave rectifier, Half wave rectifier , three wave rectifier etc.. They all have different configurations and different amounts of diodes but all of them accomplish the same general goal which is to convert AC to DC current. I looked around and found this https://www.derf.com/how-a-bridge-re...step-tutorial/ It is a good overall explanation on how they work and the different types of rectifiers. I would read through that first or maybe search around on google a bit more. This is all readily available information.
    If you still have any other questions about them let me know. Just try to be specific about what your confused on / don't understand.
    Best,
    Nov 2020
    Hey,
    Thanks so much for the thoughtful explanation. Wow just googled it , didn't realize how much information was out there. Appreciate you taking the time still.. I will do my research and see if I am confused about anything still. Will be more specific if I still have questions.
    Best,
