585,981 active members*
4,288 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal VMC 15 measurements needed please
Results 1 to 6 of 6
    Jan 2015
    5
    Hello everyone.
    I`m looking for some dimensions of the fadal vmc15
    What are the measurements of the:
    Z-collom width x depth x length?
    The base width x depth x length?
    If there is someone who could provide me with these measurements then that would be realy great.
    Thank you guys.
    May 2013
    Re: Fadal VMC 15 measurements needed please
    Google "fadal specifications pdf" and you'll get it. I will tell you if you take off the Z Axis motor you can barely fit it in a 83inch tall garage.
    Feb 2008
    547
    FWIW - Most people forget to remove (and replace) the leveling screws. Doing so will give you a little more room.
    A trick also is to have 4 sheets 1/8 x 8 x 24 of UHMW plastic ( 25 bucks at Tap Plastics) to put the machine on. Then, with a block of wood to the front of the casting, use the forklift to push it under the door.
    Before remove the servo (z) mark both the axis couplings with a felt pen, clean the servo shaft and ball screw shaft then duct tape them so they won't rotate with an accidental bump. This way you can replace them without z axis positioning problems for tool change.
    Dec 2014
    31
    I had a similar issue recently. bought a vmc15 to put in the basement. My garage door is 86" opening and I got it in with about 1" to spare by screwing the leveling feet all the way up (the pads on the bottom were welded on.) Also the Z axis motor was removed and the plastic cable carrier for the motor was unbolted and layed down to the side. Another issue I discovered that was wrong .... The specifications call out 96" top height of the machine. That was pretty close with the Z all the way down, but was about +12" with the Z all the way up! I had to box in my floor joist and cut a hole in the dining room floor to make it fit. Now I have plastic cable way that comes up through the floor. Life is hard .
    PM me if you need pics. T
    Feb 2013
    89
    Quote Originally Posted by Noyrt View Post
    Hey Noyrt,
    I know I'm resurrecting this from the dead but you are saying that even though the specifications show a height of 95.5", the machine is actually 12 additional inches at full height Z? I am also thinking about getting a VMC15 to go in my basement and definitely cant cut into the floor for additional height. Also, I would have to basically disassemble the entire machine to get it downstairs. I think that may be a mistake to try and do though. Thoughts people...?
    Apr 2014
    345
    Quote Originally Posted by NismoGT View Post
    Hey Noyrt,
    I’ll look later but the maintenance manual says the exact max height.
    I just checked it’s 101”
  1. A Few Measurements Needed...
    By SCzEngrgGroup in forum Tormach Personal CNC Mill
    Last Post: 01-30-2013, 01:15 AM
  2. Fadal service/tech needed
    By alphaorange in forum Fadal
    Last Post: 09-29-2011, 11:38 AM
  3. Fadal software needed for probe
    By H0gie in forum Fadal
    Last Post: 07-19-2010, 04:34 PM
  4. BCC V23, Fadal CNC 88 Format 2 post needed
    By cncpilot in forum BobCad-Cam
    Last Post: 05-19-2010, 06:09 PM
