585,991 active members*
4,725 visitors online*
Results 1 to 7 of 7
    Aug 2014
    21
    Machine not moving
    I can manually move in any direction, but when I try to run a program, the machine goes to position and just sits there.
    Any suggestions on at to check? Thanks!
    May 2007
    13
    Re: Machine not moving
    It would be really nice if you could give us some more information. Like: what machine are you using, beginning of your program, does machine generates any alarm message...
    Something we can start with
    What does your g-code look like?
    Aug 2014
    21
    Sorry, I'm going nuts trying to figure it out. I had a computer crash and replaced the computer. I loaded the XML file for my machine, just as I did before. The g-code is fine I believe since I have run it before without issues. The DRO in Mach3 shows the machine is moving like normal, but after I hit run, the machine goes to zero and sits there. All cables are hooked up correct and I can manually move the machine with the keyboard. It just won't run when I click the run button. Thanks for your help!
    Apr 2010
    82
    Normally with my setup, I press cycle start and a tool change message appears in the status window - pressing cycle start again actually starts the machine running.
    Mar 2013
    66
    Did you do a new install of Mach3?
    Jun 2013
    75
    The g-code doesn't run either? You hit cycle start, and the code stops running? Maybe you're calling a macro that isn't properly set up after the crash so it can't continue? You don't get an error message either?
  1. Help get my machine moving..
    By NSR_CIVIC in forum Stepper Motors / Drives
    Last Post: 02-23-2013, 10:33 PM
  2. Moving machine
    By fadalman in forum Fadal
    Last Post: 12-14-2007, 01:55 AM
  3. I've got to get my machine moving again...
    By barkster in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-01-2007, 05:31 PM
  4. Machine Not Moving
    Last Post: 11-04-2006, 04:28 PM
