585,991 active members*
5,125 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > GE FANUC α Series Control Motor Servo amplifier unit and Series 16-MB
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Feb 2015
    20
    Re: GE FANUC α Series Control Motor Servo amplifier unit and Series 16-MB
    Quote Originally Posted by underthetire View Post
    Think its only ~1100 for the package.
    What do you mean?
  2. #22
    Jun 2004
    511
    I think that means approximately 1100 Dollars.
  3. #23
    Here is a sample ladder for you. The software that they are referring to is for the newer CNC's and is only used for simulations. You can NOT run real motors from it as you want to do.
    You will have to rename this ladder file to Zone RB3.LAD as this site won't let me attach a file with the LAD extension.
  4. #24
    Feb 2015
    20
    Quote Originally Posted by drdos View Post
    Thanks, I got it. I gonna try tomorrow. Thank you so match.
  5. #25
    Feb 2015
    20
    Can I use Procomm Plus Terminal 4.8 for transfer ladder? true JD5A port?
    Should I use Null modem or Full Handshake Cable?
  6. #26
    Open it with your Fladder III software. You can compile it then export it as Handy File Then you can upload it using Procomm.
  7. #27
    Feb 2015
    20
    for some reason and couldn't communicated with CNC via RS232 port, I can't select EDIT mode.
    I do have SRAM memory, CNC detected this memory. How copy ladder file from SRAM card to CNC?
    Please help!
  8. #28
    Dec 2012
    395
    Maybe the Series 16 Connection Manual (Loader), see attachment,
    or check; Fanuc Manuals User Guides - CNC Manual for other great info.
    Regards,
    Heavy_Metal.
  9. #29
    Feb 2015
    20
    Hello every one,
    Does any body know now to activated OPR soft Key (Software Operator's Panel) on OFFSET Setting menu? There is not any OPR soft key?
    Any idea?
Page 2 of 2 12
  1. Replies: 1
    Last Post: 04-21-2014, 08:14 PM
  2. Fanuc velocity control unit (M series)
    By jhoanrojas in forum Fanuc
    Last Post: 11-12-2013, 01:20 PM
  3. Replies: 4
    Last Post: 09-14-2007, 04:34 PM
