586,011 active members*
4,532 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Need to know if KMotion has a Lathe Default Tool Table? Like Lathe.tbl
    Jul 2004
    235
    __________________________________________________ _____________
    In developing my True Machine / Lathe software... RED CNC 2L ..... I need an X Tool Offset.
    Has anyone got a modified tool table, that will work with the Kflop for a Lathe??
    See Below:
    Question:
    Attachment 269306
    Examples:
    Attachment 269308
    My Software running on the Kflop:
    Attachment 269304
    Thanks so much!!!
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    May 2006
    4045
    Re: Need to know if KMotion has a Lathe Default Tool Table? Like Lathe.tbl
    Hi Jeff,
    What Version are you using? Our later Test Versions have XY Tool Offset capability.
    KMotionCNC Tool Table Edit:
    See:
    G Code Screen
    From .NET you can access with:
    Code:
            /// <summary>
            /// Set Tool Table Entry to be used by the GCode Interpreter
            /// </summary>
            /// <param name="index">Tool Table Index Number</param>
            /// <param name="slot">Tool changer 2 digit slot Number</param>
            /// <param name="ID">Tool 4 digit ID Number</param>
            /// <param name="length">Tool length offset</param>
            /// <param name="diameter">Tool diameter used in radius compensation</param>
            /// <param name="xoffset">Tool X Offset</param>
            /// <param name="yoffset">Tool Y Offset</param>
            public void SetToolTableEntry(int index, int slot, int ID, double length, double diameter, double xoffset, double yoffset)
                _Controller.CoordMotion.Interpreter.SetupParams.SetTool(index, slot, ID, length, diameter, xoffset, yoffset);
    HTH
    Regards
    TK
    http://dynomotion.com
    Jul 2004
    235
    Tom,
    Thanks,... I am using 4.32 What version should I be using to get these new features?
    Sincerely,
    Jul 2004
    235
    OK,
    Found Version 4.33K on Yahoo... and downloaded from link... has updated tool table therein...
    - Jeff
  1. Could I turn this old round table manual lathe into a CNC lathe?
    By suraj1793 in forum DIY CNC Router Table Machines
    Last Post: 11-12-2014, 10:20 PM
  2. Replies: 3
    Last Post: 04-26-2014, 11:28 AM
  3. Replies: 6
    Last Post: 10-08-2012, 05:26 AM
  4. How to Change Default Lathe Axis (X4)
    By zeimet50 in forum Mastercam
    Last Post: 03-02-2012, 06:39 PM
  5. Anyone used FeatureCam with Omniturn Lathe / Gang Tool Lathe?
    By dbensavage in forum FeatureCAM CAD/CAM
    Last Post: 02-22-2010, 02:39 PM
