585,604 active members*
3,507 visitors online*
Results 1 to 15 of 15
    Jun 2010
    9
    E-Cut 4-Axis Controller card - need help
    Hi All,
    I am upgrading my K2 servo mill with an E-cut 4-axis controller card and was wondering if anyone has used this card. K2, as always, has been useless, and now seem to be gone. The card itself seems to be of good quality, but the wiring diagrams are vague on how or where to connect the servo encoders and E-stop. I have schematics, but they are in Chinese and I am not savvy enough to understand some of the input and output logic. I've attached some pix. Hopefully we can sort this out and help others also.
    Also, K2 has a custom breakout board attached to the G320x drivers. Have no idea what the pinout is.
    24220
    Re: E-Cut 4-Axis Controller card - need help
    Appears to be a USB card and also it mentions Modbus?
    Al.
    Albert E.
    Jun 2010
    9
    Al.
    The modbus appears to be a CAT cable connector. No mention anywhere as to function that I can find.
    Here are the English pinout specs. for the card. I'm guessing that the general purpose inputs should somehow accommodate the encorders?
    Attached Thumbnails Attached Thumbnails eCut motion control card manual V1.2-pinout 1_Page_16.jpg   eCut motion control card manual V1.2-pinout 1_Page_17.jpg
    Jun 2010
    9
    Sorry, posted above the question. And yes, it is usb. works with Mach3
    Jun 2010
    9
    No one has used this card?
    Mar 2015
    Hey kjmdes I have the same board except mine is the 3-axis controller,
    Where did you get your cases metal from?
    Jul 2012
    hey guys, i too have this board. ecut v1.2
    although with countless hours of play with the board i got spindle control stepper motor control limit with pnp sensors. i'm building a mill.
    it sure would be great to find people with experience with this board that is willing to share their experience with wiring setup and mach3 setup. i still need to figure out auto z measuring, flood mist control.
    also i forgot to mention i have a 24 v version but still running it on 12v at the moment
    anybody else interested?
    I'm running nema 42 stepper motors and 2.2 kw spindle with inverter 220 vac and pnp limit sensors
    Jul 2012
    also got spindle speed and feed rate working via potentiometer 100k:banana:
    Apr 2007
    I have an E-Cut too, and the card delivers wrong step to step motor drivers, I have tested with a leafboy77 cards and then it works as it should. Have you had similar problems? I run the card with 24 VDC.
    Jul 2012
    Quote Originally Posted by Terho View Post
    No but that sounds like an config problem you can fix in mach 3 i think. if your computer tells ecut to do 1 pulse and ecut does something else you probably have a defective card
    check in menu config/motor tuning. and also see what your stepper drivers are set at. stepper drivers can be set to different stepping and micro stepping
    ecut comes with a plugin for mach3 and changes all the preferences
    Hope this helps
    good luck
    Exclamation Re: E-Cut 4-Axis Controller card - need help
    can anyone attach the e-cut dll files please!
    i lost my cd and couldn't find the files online at all!
    Jun 2008
    4
    Oct 2018
    Hi.
    I have the same card and I´m having problems with the A-Axi. I can not move with the sofware (Mach3). Sombody else knows something about it?
    Oct 2018
    Hi matrix7y7y, also I have e-cut like a controller board. I am trying to connect the A-Axi but Mach 3 doesn't accept. Do you know something about it?
    Jan 2012
    Hi Olena, you probably have a 3-axis version of the card. Although it looks the same as 4-axis version, the firmware does not support the 4th axis (A axis).
  1. JC6560, Chinese 3-Axis Controller card
    By HSPannu in forum Stepper Motors / Drives
    Last Post: 05-07-2013, 04:59 PM
  2. Pacer old controller card to new controller box??
    By ecotrails in forum Controller & Computer Solutions
    Last Post: 09-16-2010, 09:17 PM
  3. New 3 axis controller card and open source codes
    By bunalmis in forum News Announcements
    Last Post: 04-13-2010, 08:18 PM
  4. DIY 1-8 axis PC controller card
    By karl1 in forum CNC Machine Related Electronics
    Last Post: 09-05-2007, 05:39 PM
  5. Which controller card?
    By jcolley in forum LinuxCNC (formerly EMC2)
    Last Post: 10-01-2005, 02:40 AM
