585,555 active members*
2,886 visitors online*
    Oct 2009
    19
    haas battery problem £800 $1400
    Hass mill 2011 model suddenly needs a new back up battery that should of lasted 10 years, but are going pop after just three at an amazing cost of £800 or about $1400, I nearly died when I opened the bill, how can anyone justify this expense every three years! This mini mill is not that good, doesn't even do angles, 45 degrees yes but the rest is just muck.
    Philip
    if you wish I will place the invoice on this link!
    Feb 2007
    711
    Re: haas battery problem £800 $1400
    What is the voltage and amp hour rating of the battery? I'm sure you can find a replacement somewhere much cheaper.
    Feb 2009
    6028
    We ran in to this recently. Why on earth Haas was dumb enough to hard solder a battery on the motherboard is beyond me.
    Oct 2015
    32
    I don't know where you're looking for batteries because you could literally replace the whole processor board for that price. The processor battery retails for $30 here in the US.
    Mar 2007
    2083
    have a look at this thread if you are willing to do it your self next time :-
    http://www.cnczone.com/forums/haas-m...battery-3.html
    John
  1. 2011 HAAS TM1P BATTERY REPLACEMENT??
    By hooperracing in forum Haas Mills
    Last Post: 08-18-2015, 04:00 AM
  2. HAAS BATTERY REPLACE
    By smokewagon66 in forum Haas Mills
    Last Post: 08-08-2015, 07:38 PM
  3. HAAS TM-1 NOT WORKING AFTER MEMORY BATTERY CHECK
    By eliasgr in forum Haas Mills
    Last Post: 07-01-2014, 10:10 PM
  4. Check Battery Settings In HAAS VF2 OR VF3
    By kevsterb88 in forum Haas Mills
    Last Post: 05-05-2014, 07:00 PM
