bubba198
You need the Yaskawa matching drive for your motor,(well this is the easiest way to do it ) you can use there 220v single phase drives, this is only a 200w motor so any of there single phase drives up to ( 04 ) 400w will work with that motor
You have 220v at you house that will work for these drives, this is a drive # that will work for you SGDA-04AS or a SGD-04AS, these can also be a 02 were the 04 is
Other than doing this Dmm has has low voltage Drives & motors that would work for you
DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
