585,996 active members*
4,572 visitors online*
    Jul 2011
    14
    retrofitting a km3
    I have a hurko km3 that was working erratically so I am attempting to retrofit it with a camsoft control. I started with the x axis and now when I power up, the x axis moves in the + direction at about 15 ipm. I cannot speed up, slow down, reverse, or stop. the only thing that stop it is the e-stop. I suspect I have a 5v signal telling the drive to move, but am not entirely sure how the analog signal is processed. ( as in where voltage should and should not be).
    Any suggestions would b e more than welcome!
    Thanks!
    Oct 2005
    332
    Re: retrofitting a km3
    Hello,
    If your servo drives are analog, they receive a analog signal (normally between -10 to +10v) that will say to the drive at what speed it should move. The best way to check for this will be:
    1) Make sure that your drives are analog
    2) Check the voltage that the control is sending to the drive (a voltmeter would do).
  1. CNC RETROFITTING
    By DR JADHAV in forum SIEMENS -> GENERAL
    Last Post: 09-28-2012, 03:46 PM
  2. retrofitting km3
    By tjs in forum HURCO
    Last Post: 01-17-2012, 07:01 PM
  3. retrofitting CNC lathe
    By prash in forum Uncategorised MetalWorking Machines
    Last Post: 09-20-2007, 08:55 AM
  4. Retrofitting with fanuc
    By IN-WondeR in forum Fanuc
    Last Post: 08-21-2007, 01:02 AM
  5. Retrofitting a control
    By carbidecraters in forum Fadal
    Last Post: 07-23-2007, 03:44 PM
