584,846 active members*
3,896 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc Series oi-MODEL D, Input a program from memory card
Results 1 to 13 of 13
    Feb 2015
    6
    I've read the chapters on program I/O in the user's manual about a dozen times. I'm trying to figure out how to load programs from a memory stick onto the CNC memory. Its a CNC Quaser mill. This is the directions:
    ___________________________
    8.4.3 Inputting/Outputting a File
    -A program can be input and output using the memory card screen.
    1. Press edit switch or enter state emergency stop
    2. Press soft key OPRT
    3. Press F INPUT
    4. Set the file number that you want to input. Type a file number, and press the soft key F SET
    5. Set the program number to be used after the input. Type a program number, and press the soft key O SET
    6. Press the soft key EXEC
    This starts reading the program, and INPUT blinks in the lower right part of the screen. When the read operation ends, the INPUT indication disappears.
    So this is what we do. The control is in edit mode, we are already in the memory card screen. We go to operations, we press F INPUT.
    In this screen, the programs loaded on the card are listed sequentially by their file number. There are only 5 programs on the card. So we enter the file number of the program we want (in this case, 0005). We press F SET. We enter the program number and press O SET.
    Then we press execute. Instead of "INPUT" blinking, we get a message "Program has been verified" and nothing happens. The program has not been loaded into the control, and it has not been selected as the active program. Its just been "verified" not inputted. I can't even find anywhere in the manual that explains what this means.
    Anybody who can help us from here would be great, we are trying to load programs onto this machine for our school so that students can test out their CNC programs.
    Feb 2015
    161
    Re: Fanuc Series oi-MODEL D, Input a program from memory card
    Is the program O0005 the 5th file on the list? The FSET is for which number the file is on the card.
    Feb 2015
    6
    ill try to clarify.
    F NO | FILE NAME
    0001 | O0111.TXT
    0002 | O0222.TXT
    0003 | O0333.TXT
    0004 | O0444.TXT
    0005 | O0138.TXT <-- this is the program I'm trying to load. It is in a text file named "O0138" and the program number in the code is also 0138
    I put in 0005 and press F SET, just entering 5 also "works"
    Then I put in 0138 and press O SET
    Feb 2015
    161
    Just going to check these are set.
    Make sure PRM20=4.
    In the OPRT menu, make sure device is CNC_MEM.
    Feb 2015
    161
    If you are viewing the files while trying to input, then it will just verify. You must be looking at the memory you intend the program to go to.
    2932
    If the Edit lock switch is OFF, you can load a program. If it's ON and the same number program already exists in memory, it will verify it.
    May 2009
    8
    Make sure the I/O in SETTING is 17
    Sent from my iPad using Tapatalk
    May 2009
    8
    If using USB
    Feb 2015
    6
    Thank you for your responses, i will try again today and come back with the results.
    Feb 2006
    1792
    If the selected program number already exists in the memory, it may or may not be overwritten depending on a parameter.
    Feb 2015
    6
    Quote Originally Posted by STLMachinist View Post
    Quote Originally Posted by dcoupar View Post
    Thanks these did it. We were looking at the card memory screen instead and we thought the edit key had to be on to load a program. Ill be back if there are any more issues
    Quote Originally Posted by docthal View Post
    ill try to clarify.
    F NO | FILE NAME
    0001 | O0111.TXT
    0002 | O0222.TXT
    0003 | O0333.TXT
    0004 | O0444.TXT
    The way that you're doing this is wrhong, the F SET is to set the position that the program is in your card, and the OSET is to set the position in which the progam will adopt in the memory of the machine, so let supose that you also have an program in position 0001 in the machine memory, an you want to copy the psition 0005 from your card to the machine, you will set the FSET to 0005 an the OSET to 0002 because the position 0001 is already in use.
    Dec 2009
    947
    ill try to clarify.
    F NO | FILE NAME
    0001 | O0111.TXT
    0002 | O0222.TXT
    0003 | O0333.TXT
    0004 | O0444.TXT
    go in the cnc mem directory and type :O0111 and hit"READ" ,will read the program from memory card and copy to cnc mem space.
  1. Replies: 4
    Last Post: 04-17-2014, 10:50 PM
  2. Fanuc Memory card
    By CNC1970 in forum Fanuc
    Last Post: 04-05-2014, 05:26 AM
  3. memory card of FANUC 15MB
    By jeff.liu in forum Fanuc
    Last Post: 05-08-2011, 01:37 AM
  4. Where/How to buy Fanuc Memory Card
    By marcwdci in forum Fanuc
    Last Post: 07-19-2008, 02:57 PM
  5. Fanuc 16i memory card
    By jamie pinols in forum Fanuc
    Last Post: 02-26-2007, 01:50 AM
