Originally Posted by
dertsap
there should be a parameter to control the on time
i heard this when i started my apprenticeship, there is a parameter you can change to make your machine use more oil (this means less wear on machine components, but more way oil in your coolant resulting in suffocation of your coolant, thus it goes off) or vice-a-versa less oil (more wear on components but less oil in your coolant)
note: if you have a skimmer for your coolant tank you should not have any problems with way oil suffocating your coolant.
On the other hand, You have different fingers.
