Re: RF30 motor replacement
Martin,
Back when I got mine, I got a package deal from Dealers Electric.
Back then, sensorless vector drives were a real premium and I didn't go that route. Today, I definitely would get a sensorless vector drive as it allows improved low speed torque. I might also look at a slightly larger motor again to have more torque in the low speed ranges. I replaced my original Chinese 2hp motor on my RF31 with a Leeson 2hp 3ph. IF I were to redo it today, I probably would go with a 3hp and sensorless drive. There are lots of good drives out there but I would stick with known good suppliers and tend to shy away from the inexpensive drives that you find on ebay. Of the two that I have, both are Teco's and they work fine off single phase. As a matter of fact the EV7200 that I got for my lathe doesn't even have a three phase input.
As mentioned above, ebay can be your friend as I got both the motor and drive for the lathe off there.
PS: yes the original motor had a metric shaft on it and the Leeson has imperial. I reamed out the original pulley to fit. It is my intention someday to make new pulleys to better match the speed range and have fewer belt change positions.
Art
AKA Country Bubba (Older Than Dirt)
