585,758 active members*
4,133 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
Page 2 of 2 12
Results 21 to 34 of 34
  1. #21
    Jan 2009
    334
    Re: Denford NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
    I have had to repair the encoder, it was faulty / defective. I have posted all the information that I could locate that might identify the encoder.
    It appears to be a 755A with a 10mm shaft with flat. In the Novaturn, only A and index are used.
    I modified my encoder to provide all signals, A A', B B', Z Z' which will be used for position control.
    I had to replace the ET7272B as it was faulty. I may modify the case to accept a 10 pin connector for quick disconnect.
    For those of you who might have a damaged or faulty encoder, please see the information below.
    I am currently designing a circuit to interface the Hardinge control panel to the MESA 7i77. This circuit will control the leds and membrane switches without using any additional I/O on the 7i77.
    Has anyone else looked at the Gizmosphere for CNC / control applications?
    I hope this helps,
    Iron-Man
    Attachment 295004
    Attachment 295006
    Attachment 295008
    Attachment 295010
  2. #22
    Jan 2009
    334
    PathPilot on AMD Gizmosphere1, T40E + iBOB2
    I am almost finished. I have PathPilot running on the GizmoSphere 1.
    Specs:
    G-T40E dual-core processor running at 1.0 GHz, combined on a single die with AMD Radeon™ HD 6250 discrete-class graphics. The board provides a performance capacity of 52 gigaFLOPS (GFLOPS) at less than 10 watts. Custom high- and low-speed edge connectors enable a full range of functions. This unprecedented level of integration between serial and parallel processing offers a power-efficient foundation for high-performance multimedia content delivery across a broad range of embedded designs such as digital signage, x86 set-top box (xSTB), IP-TV, thin client, information kiosk, point-of-sale, casino gaming, media servers and industrial control systems.
    Currently decoding I/O on the Hardinge interface. The MPG, Axis select, and Rapid Override are functioning under Linuxcnc. I just need to change the bit file and 7i77 I/O for complete functioning.
    Attachment 297500
    Attachment 297502
    Attachment 297504
    Iron-Man
  3. #23
    Jan 2009
    334
    Progress updates.
    Attachment 300600
Name:	28 TPI Threads Test.jpg
    Iron-Man
  4. #24
    Jan 2009
    334
    The Denford NovaTurn uses Inductive Sensors, BES 517-352-NO-L. I currently have them functioning in PathPilot. X and Z reference works correctly and also sets the soft limits.
    Will post video soon and use PathPilot to make initial test parts.
    Iron-Man
  5. #25
    Jan 2009
    334
    I had to change out the Denford tool post to a AXA style quick change tool post. Now I can follow the 15LSlant-Pro videos for tool offsets and set-ups. I am still looking for a suitable auto tool changer to modify for this lathe. Initial test cuts look promising. Initial diameter 0.3312 wanted 0.3151( Yaskawa SGMP motor shaft diameter), measured with micrometer 0.3153, delta = 0.0002.
    NovaTurn test cut
    https://youtu.bevyPam3cM6AE
    AXA Style Quick Change Tool Post
    PathPilot Screen Initial Diameter 0.3312 reduce to 0.3151
    Micrometer reading 0.3153, Delta = 0.0002
    Pulley on shaft
    iBOB2 + GizmoSphere
    Iron-Man
  6. #26
    Jan 2009
    334
    Sample test part. Will post more video later.
    Attachment 313514
    Attachment 313516
    Attachment 313518
    Iron-Man
  7. #27
    Nov 2005
    218
    Is that an Emco turret that you will adapt to the Denford? I'm following this build with interest as well as Smokediver's Emco thread.
    I have a PC turn 55 (running on WinNC) and am about to take delivery of a 120 that will need a retrofit as the electronics are inoperable at the time and may not be salvageable. I have a Tormach mill too, so I would love to get them both working with PathPilot but know little about linuxcnc and its underpinnings.
    Would you be willing to share what you have learned about configuring Pathpilot lathe for other machines? I am super comfortable with the electronics and mechanical side of things, it is the software configuration on Linux that scares me.
    Keep up the great work!
  8. #28
    Jan 2009
    334
    Quote Originally Posted by jcposada View Post
    Yes, it is a Emco turret. I am also doing the refit for Smokediver. Let me know if you want to upgrade to servos.
    Iron-Man
  9. #29
    Nov 2005
    218
    Quote Originally Posted by Iron-Man View Post
    Iron-Man
    For the big one, yes I think I will have to move to servos. For the little one, not unless that is the only way out. I believe the steppers and drivers that are currently in place can be made to work with a mesa card based on some threads I have seen on the linuxcnc forums.
  10. #30
    Jan 2009
    334
    As promised, a short video of referencing the X and Z axes.
    https://www.youtube.com/watch?v=ozDqLAXRat0
    Iron-Man
  11. #31
    Jan 2009
    334
    Denford NovaTurn refit with AC servos.
    1/4 20 thread test with sample parts.
    Iron-Man
  12. #32
    Nov 2009
    4415
    Nice job.
    I see you are running Path Pilot. Do you intend to have that tool changer front or rear mounted? If front mounted, do you see any issue setting up Path Pilot's tool page or format?
    I am just starting to learn LinuxCnc. I would enjoy using that kind of set up. There is plenty to learn there before that happens ;-)
    A lazy man does it twice.
  13. #33
    Jan 2009
    334
    Quote Originally Posted by Fastest1 View Post
    Nice job.
    Thanks Fastest1
    I am looking at both options. Pathpilot uses a pwm signal to encode the tool number. I will be using a pic micro to decode this for a transparent interface to path pilot.
    Iron-Man
  14. #34
    Jan 2009
    334
    I started my conversion of a EMCO Tool Turret a few weeks ago.
    STATUS:
    EMCO Compact 55 Tool Changer modified with a AMT203 ABS Encoder with SPI interface.
    ARM LPC1768.
    The encoder interface is now working.
    Denford NovaTurn AC Servo Lathe used to make new encoder adapter.
    The set-up uses the existing tool changer board. I am in the process of designing new board to replace the EMCO, that will have its own motor driver.
    Next step is PathPilot interface to MESA 7i77.
    Iron-Man
Page 2 of 2 12
  1. Anyone ever retrofit a Servo II system?
    By frontrange in forum Post Processors for MC
    Last Post: 04-05-2020, 10:57 PM
  2. AMD Gizmosphere Embedded Computer + iBOB2
    By Iron-Man in forum Controller & Computer Solutions
    Last Post: 02-14-2015, 12:01 AM
  3. Servo Retrofit MAHO 600 P
    By nissse in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-25-2011, 07:55 PM
  4. Servo Help, Series 1 Retrofit
    By Jet A in forum Bridgeport / Hardinge Mills
    Last Post: 02-10-2010, 08:40 AM
  5. 3phase servo retrofit
    By whiteriver in forum Servo Motors / Drives
    Last Post: 02-07-2005, 04:27 AM
