585,702 active members*
4,295 visitors online*
Page 3 of 3 123
Results 41 to 50 of 50
  1. #41
    Feb 2005
    154
    You might be more successful if you try posting a new thread.
    No one else is answering so I will try to help with the little that I know.
    First, I have never communicated with any of these machines through a rs232.
    This control is pretty much the same as the EZPath and the EZtrak. These controls are basically an old 486 computer that is running dos 6.2. (if they haven't upgraded, they probably have an older version of dos) The EZtrak mill three axis has the ability to actually drip feed. From what I can tell the lathes and the two axis EZtrak can not, but you can transfer a program to the hard drive on all of these machines through the rs232 port. Then you could load it and run it.
    I guess the manufacturer at that time thought that you wouldn't need to run a program over 256K (the capacity of the buffer) on a two axis mill or lathe.
    I have included an attachment I scanned out of my PowerPath manual that may help you out. From what I can see it would be similar to transferring a program through a serial port on an old dos PC as you would before windows came on the scene.
    If you do get it figured out, could you let me know? I have very seldom had to run a program larger than the capacity of a floppy but I would like to know how it's done.
    Pete
    Attached Files Attached Files
  2. #42
    Apr 2006
    14
    anybody can help with a power path problem.
    i had this PP15 turret crash onto a work pc. then the turret got into the unclamp position.
    alarm "turret not in position" appear n screen. I manage to reposition the turret back in clamp mode with the solenoid of the hydraulic system but the alarm is still there. looking at the back of the turret where there are proxi sensors and they are working fine.
    hope somebody can give me some advice. thanks
    Jason
  3. #43
    Apr 2015
    Re: Romi-Bridgeport PowerPath 15 users?
    yo estoy reparando uno
  4. #44
    Jan 2011
    7
    Good afternoon... I'm from Coahuila Mexico... I have a torq cut 22 with all its manuals (electrical, mechanical and programming) and I also have a power path 15 that I'm rehabilitating, but I don't have the electrical diagrams (well none ) Could you help me with this? If you need something from the torq cut 22, I will gladly support you!
  5. #45
    Jan 2011
    7
    Do you have manuals electrics and parts of power path 15?
  6. #46
    Jan 2011
    7
    Post Re: Romi-Bridgeport PowerPath 15 users?
    Quote Originally Posted by rfranco View Post
    Good morning... does anyone have the electrical diagram # R68467 of power path 15?
    Thanks in advance if someone can help me...
    Greetings from Coahuila Mexico
  7. #47
    Jan 2011
    7
  8. #48
    Jan 2011
    7
  9. #49
    Jan 2011
    7
  10. #50
    Feb 2023
    i have problem with 1
Page 3 of 3 123
  1. Bridgeport/Romi EZ Path 2 SD
    By JRN in forum Bridgeport / Romi Lathes
    Last Post: 08-14-2020, 02:42 PM
  2. Bridgeport Powerpath X axis problem
    By amgearinc in forum Bridgeport / Romi Lathes
    Last Post: 06-06-2011, 04:56 PM
  3. Bridgeport Powerpath lathe turret spinning
    By Larry Callahan in forum Uncategorised MetalWorking Machines
    Last Post: 02-10-2010, 04:44 PM
  4. Bridgeport powerpath 15
    By Nadda` in forum Bridgeport / Hardinge Mills
    Last Post: 01-06-2010, 06:22 PM
  5. Bridgeport Romi Password
    By md63825 in forum Bridgeport / Hardinge Mills
    Last Post: 08-16-2007, 11:53 PM
