585,992 active members*
6,309 visitors online*
    Feb 2014
    9
    PMDX-126 A/C outputs not working
    Hi all,
    I can't enable the 10A and 20A outputs on my control box.
    All jumpers are set to PMDX-126 manual directives.
    All DIP are closed, no spindle, no limit switches.
    It's a simple build, PMDX-126 and PMDX-134 with 203v.
    The output enable K1 and K2 leds are on.
    Output signals are enable in Mach3 for Pin 1 and pin 14.
    I'm out of ideas.
    Feb 2014
    9
    Re: PMDX-126 A/C outputs not working
    A quick call from Cory solved the issue.
    Those guys are amazing, this problem was 100% my fault.
    And it was quite an embarrassing realization for me.
    But Cory was all the way respectful.
    If any of you guys have doubts in your limited ability to make a CNC up and running, just do your homework well and Ahren and Cory will provide the rest.
    Again, simply amazing.
    Nov 2013
    143
    Quote Originally Posted by Sylvain Gingras View Post
    I'd like to echo this comment. Cory and Ahren are absolutely amazing guys.
    I had a lot of trouble (mostly my fault) with my machine, and these guys went so far beyond the call of duty, I was blown away.
    Now, my machine is running flawlessly, and my business is reaping the rewards ;-)
    Couldn't be happier with the service from CNCRP.
  1. Replies: 0
    Last Post: 02-26-2014, 03:41 AM
  2. Having Issues w/ PMDX-126 PMDX-134 and Ethernet Smooth Stepper
    By Hurshy in forum Community Club House
    Last Post: 08-27-2013, 01:20 PM
  3. G540 Outputs stopped working
    By rk396 in forum Gecko Drives
    Last Post: 09-25-2011, 07:53 AM
  4. Galil analog outputs working?
    By Karl_T in forum Controller Cards
    Last Post: 11-25-2008, 03:26 AM
  5. Opto 22 / ICM outputs not working
    By mzartop6 in forum CamSoft Products
    Last Post: 01-28-2006, 05:35 AM
