585,761 active members*
4,007 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang 2.2 KW VFD Input Voltage Question.
Results 1 to 13 of 13
    Dec 2014
    17
    I am building my first 4 Axis CNC Router, project is almost done and working on wiring the 2.2 KW Spindle with a Huanyang VFD.
    I am a little confused on wiring the R S T input to the VFD.
    I live in the U.S.
    I am wiring the input with 220 VAC. Three wires. 1 - 120 VAC; 1 - 120 VAC and one Ground wire.
    i searched the internet, most what I found is 2 wire connection. Hot wire to R and T to ground.
    I don't want to fry anything up and just wondering if somebody can help me.
    How should I wire the input?
    R - 120 VAC?
    S - 120 VAC?
    T - Ground?
    Thank you in advance for any help!
    Uni-CNC
    Re: Huanyang 2.2 KW VFD Input Voltage Question.
    Do not wire the ground to the T terminal. There should be a separate ground terminal, possibly labeled E? On the Ebay auction I looked at, it looks like ground is 9?
    R and S sounds correct, but I don't have one of these to say 100%.
    24220
    The input is a 3phase rectifier so connecting the 240v L1 & L2 to any R,S or T pair will work, do NOT connect the GND to anything but the E terminal.
    As the Manual says "R.S.T input current if the single-phase source meets two willfully"?
    If you understand that 'Chinglish' let me know!
    I used R & S.
    Make sure the ground conductor also goes to the motor frame.
    The manual is online if you don't have it.
    Al.
    Albert E.
    Dec 2014
    17
    Al,
    Thank you for your help.
    I will connect the 2 hot wires to R & S and ground wire to ground on VFD.
    Dec 2014
    17
    Ger21,
    I took a picture of the VFD terminals.
    like you and Al said. I will connect R & S (Hot).
    and Terminal 9 to ground.
    Attachment 271454
    15362
    Uni-CNC919
    You also have to set the Parameters correct, here is what you will need to use to get it safely running, failing to set the Parameters correct will Damage the Drive
    Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220
    PD011=120 (Minimum Setting 120)
    PD009=15
    PD010=8
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Accel=12 ( Adjust to suit)
    PD015 Deccl=12 (Adjust to suit) ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage )
    PD142=9 ( Motor Max Amps) (Set for your motor Amp Rating 2.2Kw Spindle 9 amp Max)
    (Set for your motor Amp Rating 1.5Kw Spindle 7 amp Max)
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    Mactec54
    Pls check video here
    2.2KW (3HP) VFD Spindle Inverter (KL-VFD22) 220VAC input | Automation Technology Inc
    VFD Parameter set:
    PD001 = 0 (1 for external control)
    PD002 = 0
    PD005 = 400
    PD004 = 400
    PD003 = 400
    PD023 = 1
    PD141 = 220
    PD142 = 11.0
    PD144 = 1440 ( less than 2500)
    24220
    There is also a neat Huanyang Modbus plug in control if using Mach.
    Mach3 plugin for Huanyang VFD | Le royaume d'éole
    Al.
    Albert E.
    Dec 2014
    17
    Mactec54,
    Thank you.
    This will help me a lot.
    Uni-CNC919
    Dec 2014
    17
    Thank you for the information.
    First time I've seen the first video.
    I have seen the second one..
    Uni-CNC919
    Dec 2014
    17
    Al,
    Thanks again.
    I am using the demo version of Mach 3 and will be buying the license for it this coming week.
    This will be the first time I will be using Mach 3 and also the first time I built a CNC router.
    Still learning.
    Kinda slow, I work full time and just work on the CNC router a couple of hours at night.
    I have Mach 3 working on my CNC Router and now working on the spindle wiring and configuring the Autozero set.
    My auto zero works but have a little bug on it. Still playing with it.
    I have copied several script to edit the auto zero button but non of them works perfect. there's some fine tuning to do.
    You mentioned something about Modbus Mach 3 Plug in for Huanyang.
    Can you elaborate more on this? What does this do?
    Here's a shot of the CNC Router where I am so far. I still have to install the T slots on top of the table.
    Attachment 271508
    Thank you for your help again and also thanks again for everybody who help me on this thread.
    24220
    There is a link in my last post to the author and also on the Mach forum there is an extensive thread, If I can find it I will post it.
    It uses a three-wire serial or USB/serial converter to communicate with the VFD.
    Al.
    Albert E.
    15362
    Quote Originally Posted by automationtechinc View Post
    VFD Parameter set:
    PD002 = 0
    PD005 = 400
    PD004 = 400
    PD003 = 400
    PD023 = 1
    PD141 = 220
    PD142 = 11.0
    The numbers you have posted are incorrect
    PD142=11 is an incorrect setting, for this motor Max Amps
    PD144 incorrect setting, needs to be set to 3000, for max spindle RPM
    PD023=1 is the Factory Default, putting it in your list is only confusing for new users
    Mactec54
  1. Huanyang VFD Multi-input/output question
    By Ozzwinkle in forum Spindles / VFD
    Last Post: 02-03-2014, 03:22 AM
  2. chnc input voltage around 214-217 need 230v
    By snascar2424 in forum Hardinge Lathes
    Last Post: 08-16-2011, 03:05 AM
  3. Card Voltage input?
    By jrsaw27 in forum Controller Cards
    Last Post: 07-14-2011, 05:16 AM
  4. Is this Input or output voltage
    By Mr.Chips in forum Xylotex
    Last Post: 01-24-2007, 04:36 PM
  5. Odd input voltage???
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:05 PM
