KL-1212 CNC Router ~48? x 48? x 6.0?, with Mach3 or Mach4 control using Ethernet SmoothStepper Board
Pls check here for detail
http://www.automationtechnologiesinc.com/products-page/cnc-router/kl-1212-cnc-router-48-x-48-x-6-0-run-at-220vac-with-vacumm-table
KL-1212 CNC Router ~48" x 48" x 6.0" with Vacuum Table
You can run the router at 110VAc or 220VAC with a step-up transformer ( It is not included, $100 to update), 110VAC to 220VAC
Brand New CNC Router Engraving Machine with Mach3, 4 Controller, 2.2KW Spindle + 2.2KW 400Hz Variable Frequency Drive
You can come to our show room to check the machine.
We will send you a paypal request for shipping fee difference
We Changed this Machine to Mach3, 4 Controlled System.
Machine Size: 1620 x 1610 x 1230 mm
Working Size X,Y,Z : 1200 x 1200 x 150mm ( about 48" x 48" x 6.0")
Resolution: about 0.002"
X, Y, Z Repeatability: 0.002"
Working Speed : 200 -350 IPM
Mach3 Controller with Mach3 Software ( Mach3 license file is not included)
Spindle Power Motor: 2.2KW, Water-Cooled, ER20 Collet Chuck
Spindle Speed: 0-24000 rpm With VFD, AC220V/50Hz/60Hz
X, Y, Z axis driver: Stepper Motor Driver
X, Y Z Limit Switch
6 Axis Breakout Board Optical Isolated
E- Stop
X Axis: 20mm Support Rail, 16 mm Ballscrew
Y Axis: 20mm Support Rail, 25mm Ballscrew
Z Axis 20m Linear Rail, 16mm Ballscrew
Wood Packing Dimension: 1830mm x 1730mm x 1450mm
one year USA parts warranty
Mach3 set up for kit and machine, Download here
Mach3 Setup (Mach3Mill.xml file) (6359)
Mach3setup (9340)
Mach3Tutorial (154463)
List Date: 3/8/2015
For more info, click here to view the original listing: KL-1212 CNC Router ~48? x 48? x 6.0?, with Mach3 or Mach4 control using Ethernet SmoothStepper Board
On Sale For: $6,899.00 + $399.00 Shipping
Mobile friendly version: KL-1212 CNC Router ~48? x 48? x 6.0?, with Mach3 or Mach4 control using Ethernet SmoothStepper Board
Go Mobile: Download the free Panjo iOS app now!
