584,850 active members*
4,465 visitors online*
    Feb 2009
    237
    Step Resolution Question
    OK guys, I have been pathpiloting this weekend and there is one item which is puzzling me.
    When I installed Path Pilot, the install asked me which machine I had. I specified Series II with a larger than 1400 Serial number without the Series III upgrade.
    I am under the impression this should mean my steppers can move as little as 0.0005 inches. However, when I am at PP, the smallest step size is 0.0001" instead of 0.0005". In fact, there is no 0.0005" option. What am I missing here?
    The weird thing is that my machine does move 0.0001" per step, which is weird as I thought the bipolar steppers and the leadshine drives were not capable of this resolution.
    I document my CNC Experience at CNC Dude's Youtube channel. Check it out!
    Jun 2006
    3063
    Re: Step Resolution Question
    My Series I mill has always been capable of 0.0001" moves.
    Mike
    Sep 2009
    1856
    have a look at the linuxCNC 2.7 setting it has a thing for Series II machine`s might be different.
    if you wont I can get it on Thursday for you
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  1. newbie question on step by step cutting setup/ process in Mach3
    By Matt Clara in forum Mach Software (ArtSoft software)
    Last Post: 05-27-2014, 07:36 AM
  2. Question about Microstepping - Resolution+more
    By Aryantes in forum DIY CNC Router Table Machines
    Last Post: 04-09-2010, 02:28 PM
  3. BOSS 6 resolution question
    By Agmachines in forum Bridgeport / Hardinge Mills
    Last Post: 07-06-2007, 12:11 PM
  4. Resolution question
    By pstockley in forum Servo Motors / Drives
    Last Post: 12-21-2005, 06:06 PM
  5. Single Step/Half Step Question
    By Hawkeye in forum DIY CNC Router Table Machines
    Last Post: 11-20-2003, 05:28 PM
