I'm already noticing my CNCRouterParts Standard rack & pinion drive pinion is shedding metal dust. The rack is located on top of the gantry in my design, and there's a visible buildup after about 10 hrs of runtime- most of which was running raster up and down the gantry, so it has been doing a lot of travel.
It's set at 60 in/min/min acceleration. I have the tension set maybe a bit conservative. I did find that it doesn't seem to take much at all to keep the pinion from slipping, but I did of course tighten it down a lot from that point.
The pinion's end is level with the bottom of the rack right now. That wasn't quite the original intent, there is room for the pinion to extend past the rack without rubbing on the gantry, but the mounting went a bit differently in the end and a significant part would have to be remade.
I did add some molybdenum dry lube to the R&P. I don't want to use grease in this environment, sawdust getting into grease can create a worse problem than it solves.
Any ideas?
