584,858 active members*
4,487 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Detroit Diesel 2 stroke drawings
    Jul 2010
    24
    Please share your drawings of the 2 stroke Detroit Diesel engines, including the 53 and 71 series Vee and inline configurations.
    The goal is to compare those designs with a project design that can operate a higher running speeds.
    Oct 2006
    708
    Re: Detroit Diesel 2 stroke drawings
    Freefuel, the factor that determines the operating speed range and limit is not so much the number of cylinders or the cylinder arrangement, as the stoke length of the engine. The inertial balancing method does help, but mostly long stroke engines reach maximum allowable piston speeds at lower RPM. Inertial loads of reciprocating parts quadruple when you double the engine RPM for a given configuration.
    Consider a model 2-stroke engine with a .75" stroke running at 15 to 20 kRPM. Consider a Ferrari V8's rev to 9kRPM, despite their "flat" crankshaft to even out firing pulses at the expense of inertial balance. This is possible because Ferraris use large bore to stroke ratios, or more specifically, short stroke engines.
    The same principles apply to diesel engines, except that peak power speed for a 2 liter 4 cylinder diesel may be 4000 RPM, while that of a truck diesel may be only 2000 RPM due to its longer stroke length.
    Research power band and redline RPM VS stroke lengths, and you will see what I mean.
    Jul 2010
    24
    ok one at a time then, lets stick to the drawings.
    Oct 2006
    708
    Good luck.
    Jul 2010
    24
    Quote Originally Posted by dynosor View Post
    Good luck.
    I found some 3 view drawings of fully assembled engines, they are good for reference if you were trying to fit them into something or perhaps trying to replace them with something else.
  1. Short Stroke, 3 cyl turbo diesel
    By mutt_78 in forum I.C. Engines
    Last Post: 07-25-2013, 10:00 AM
  2. Diesel Engine Project
    By SB123 in forum I.C. Engines
    Last Post: 07-07-2013, 05:40 PM
  3. Need Diesel Fuel?
    By eartaker in forum I.C. Engines
    Last Post: 07-29-2011, 05:42 AM
  4. drawing board drawings to cad drawings
    By mike hide in forum Uncategorised CAM Discussion
    Last Post: 03-23-2009, 10:35 AM
  5. Replies: 0
    Last Post: 12-18-2006, 01:23 AM
