Re: DIY Drag Knife Test
Most drag Knives I have seen cut at a maximum of 1/16" into material. I am not sure if this could have played a part in the difference you had noticed; as well I have known people to be mostly challenged while creating the G-Code for the blade to operate within. Watching a Drag Knife work, you could easily see where the difficulties in programming could come from. The challenge becomes getting the correct offset settings. Maybe break down and review the code and give it another try in a thinner material possibly? I am by no means an authority on drag knives, so if you find anything out that resolves the issue, could you possibly post a response stating what you had discovered. Thanks!
"The one who follows the crowd will usually go no further than the crowd..."
-Albert E.
