I guess I have been sleeping. Sometime in the past Tormach started drilling a hole in their TTS-measuring surface plate to accomodate the toolholder shank and eliminate the need for the ground spacer: 31713 - Small Granite Surface Plate with Integrated Tool Hole
What a genius idea! Eliminates one interface in the measurement chain, together with maintaining (i.e. keeping rust-free) the spacer.
I already have two surface plates, and one is the one that came with my TTS set years ago. I know that DIY drilling of granite countertops is commonly done (witness endless Youtube videos) so I figured "how hard can it be anyway?" (I know, famous last words, but this came to a happy ending)
I Googled around and found a good number of recommendations for the diamond-studded core drills from THK (not the esteemed bearing manufacturer, but Treasure Hong Kong) on eBay. $9 with free shipping for three 20mm core drills. 20mm is slightly larger than the .750" TTS shank, so it would be safe, especially with any runout (in this case, to be desired...) Just search for "20mm THK diamond coated core saw" on eBay and you'll find them. The seller even emailed me before the bits even shipped. Very friendly guy and I recommend him.
The bits came in about a week and tonight after work I decided to give it a try. The SOP for core-drilling granite is to build a small dam around the area with plumber's putty and make a little pond of water to lubricate the cut and contain the generated dust. Spent 5 fruitless minutes trying to find my plumber's putty, then decided to make a dam using some camper mounting tape (single-sided closed-cell foam tape).
I chucked up the first core drill in the drill press, turned the spindle on at the speed it was already set at (turns out to be 600 rpm) and applied slight downwards pressure on the bit. It took literally 30 seconds to sink the bit into the surface plate to the point where it wasn't cutting any more. So I stopped and got a small flat-bladed screwdriver and wedged into the cut, tapped it down with my dead-blow hammer and broke off the core, which was easier than I thought it would be.
I soaked up as much of the water/dust sludge as possible with a couple of paper towels, poured in fresh water, and drilled down further. I broke off the second core, and stacking them up it was iffy as to whether I was deep enough. One TTS shank fit in and the toolholder bottomed on the ring on the plate, but I wanted to be extra sure.
I drilled down further, to where the body of the core drill was even with the surface of the plate. I spent probably 15 minutes trying to break off the third core, then decided to drill somewhat deeper to increase the aspect ratio of the core. Then I was able to break it off on the first try. Object lesson: the core needs to be at least as deep as its diameter to be able to stress the base enough to fracture off.
Given my false starts and all, it took less than half an hour to core the hole. I smoothed the entrance with a grinding bit in my Proxxon hand tool and washed the plate off well. I am more than happy with the results.
I did not even begin to dull the first core bit, much less need the other two. I arleady have some small padded envelopes, so if two of you want to mod their plates like this I'll sell the two unused bits for $4.00 each (basically for shipping and trip to the post office) if you PM me.
Obviously, I'll need to redo my tool table, which is old-school measure-on-the-plate-and-type-in-by-hand in Mach3, but it's about time to do that anyway given my tool churn recently.
Randy
