Do you know if there is a way to cut and engrave on the same job? I need to cut the design and card out, but also need to score at the fold lines. TIA
Christine
Christine
You have to send both though so it places the engraving in the correct spot. In order not to engrave the cut, change it's color to white (RGB) and the laser wont 'see' it.
It's a pita but it works. Here's a video I did of it as well, including what to change your settings to.
https://www.youtube.com/watch?v=MR7967VHKnI
Wellll, seems if i open the object manager everything crashes?
Make sure you launch CorelLaser in admin mode, and it will launch CorelDraw.
You don't really need the object manager (it helps a lot), just select the object with your mouse, and then hit the engrave/cut buttons.
Also one different sample, Focusing engraving and cutting works.: Focusing engraving and cutting works. - YouTube
Okay, i can get the card to cut, but when I try to get the score lines to engrave it engraves the line at the top left, not where it belongs........Help me please
