I've got a file that I drew in AutoCAD that I would like to v-carve on my router. I tried using the v-carve routine in BobCAD V26, but a large portion of the drawing is destroyed and the toolpath for some reason continues down to Z = -12.97" despite the bottom level being defined as -.125" in the v-carve wizard.
Every single shape in the drawing is a closed polyline in AutoCAD. I can hatch the area that I would like to get v-carved, and can also extrude the drawing and get solids, so I know there are no self intersecting curves and the shapes are "watertight". Strangely, the lower half of the drawing comes out as intended in the simulation, and the upper half is consumed.
This is what the drawing should look like (hatch generated in AutoCAD).
This is what is happening in the V-Carve simulation:
Does anybody have an ideas on what might be causing something like this to happen?
Thank you,
Jonathan
