585,556 active members*
3,579 visitors online*
Thread: Renishaw OTS
    Mar 2015
    Renishaw OTS
    I am installing a Renishaw OTS on a new machine with a Fanuc Oi controller.
    I have set it up and run the calibration cycle.
    Everything appears to be working well except the radius geometry output.
    When I measure the tool, the radius geometry is output as the full radius of the tool.
    (a .498 diameter end mill is output as .249 in the too radius geometry.)
    I need the output to be the delta value of the difference between the expected radius and the measured radius.
    (a .498 diameter end mill programmed as .500 = radius geometry output should be -.001)
    Can anyone tell me what I need to do to get the desired output?
    Brian
    24220
    Re: Renishaw OTS
    Renishaw usually come with a set of macro's, in the 0 it would be the 9000's.
    You could modify one or write your own?
    Al.
    Albert E.
    Mar 2015
    Re: Renishaw OTS
    I wrote my own sub program to do the math and adjust the value in the offset address to be what I need.
    It works good, but I would rather just adjust whatever needs to be adjusted inside the Renishaw programs/variables.
    That way I don't need an external sub program that needs to run with the toolsetting macro program.
    I just cant believe there is not an option within the Renishaw software to change the output.
    Most part programs that I have ever seen are programmed using the tool diameter. The current output from OTS is for a programmed zero diameter tool.
  1. Renishaw
    By finaburger in forum Calibration / Measurement
    Last Post: 01-15-2012, 08:24 PM
  2. Renishaw MP3
    By GrahamIT in forum Calibration / Measurement
    Last Post: 12-26-2010, 10:38 PM
  3. Renishaw MP 700
    By luke1626 in forum Fanuc
    Last Post: 03-24-2010, 12:19 AM
  4. Renishaw OTS
    By rbest27 in forum Haas Mills
    Last Post: 05-07-2008, 08:17 PM
  5. Renishaw CP1
    By Dancy in forum Calibration / Measurement
    Last Post: 01-18-2008, 04:57 PM
