585,555 active members*
3,347 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Adding 4th Axis to RoboDrill - How do I set the machine to see the 4th axis?
    Mar 2015
    I have a Robodrill D14Mia5 with a 31I/M5 controller that came stock with 3 axis.
    I added a Fanuc servo amp and motor to the machine as per the manual, but the machine dosent see it.
    Is there a way I can get the machine to see the 4th axis so I can run my 4th axis?
    Scott
    Feb 2015
    161
    Re: Adding 4th Axis to RoboDrill - How do I set the machine to see the 4th axis?
    That is an option to add axes. An option file needs to be uploaded to the control and the proper servo parameters set. Unfortunately, you will have to consult your dealer about getting that updated.
  1. Adding 4th axis (rotary) to a 3 axis cnc router
    By Azalin in forum DIY CNC Router Table Machines
    Last Post: 03-05-2015, 09:50 AM
  2. Replies: 26
    Last Post: 05-24-2014, 03:41 PM
  3. adding the 4th axis (a) to the machine
    By nice-day in forum Fanuc
    Last Post: 05-24-2013, 02:15 PM
  4. Robodrill z axis alarm
    By ikhwan in forum Fanuc
    Last Post: 12-09-2012, 06:57 AM
  5. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
