585,560 active members*
3,382 visitors online*
    Apr 2004
    Stepper connector type?
    I'm looking for a part number or source for the connector used on PacSci and similar steppers. It's an 8 position MTA100 header, but who makes it?
    Note that I want the header, the male portion present on the stepper, rather than the receptacle, as used in the wiring. PacSci specifies the AMP 641653-8 for a receptacle, but I haven't found a matching header.
    Thanks for the help!
    click
    Jun 2004
    463
    Just go to www.amp.com and search for 641653 and you will find a list of all compatible headers. Better yet, just go to www.digikey.com and search for MTA. http://dkc3.digikey.com/PDF/T063/0132.pdf
    Apr 2004
    *smack* (slaps forehead)
    I forgot completely about looking at AMP!
    Thanks Jeff...
    I actually tried Digi-Key first, searching for MTA and had no luck. They list the recepticles that way, but not the headers. Found a part number on the AMP site for headers that matched, and DigiKey had those.
    click
