I've been able to create a tools list for an imported 3D model in order to obtain a hardcopy with a view(s) of the model as well as some of the dimensions of the model. Is it possible to do the same for a 2D design done with the 2D geometry tools? I have been able to get the 2D model drawing to show up but not the dimensions. If one designs a model within Sprutcam it would be really nice to be able to visulaize it along with its dimensions.
Also, a question about using the calculator in the 2D geometry mode to make measurement. I found that most measurements can be made on the contour layer but I have to go to the geometry layer to make others. For instance for a line I can get the length while on the contour layer but I have to go to the geometry layer to get the angle. The manual isn't clear but is this the way it is supposed to work? Am I supposed to go to the geometry layer to make measurements?
