585,668 active members*
4,047 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Ezilathe, a useful aid to lathe programming.
Results 1 to 20 of 211
Threaded View
  1. #11
    Apr 2009
    125
    Re: Ezilathe, a useful aid to lathe programming.
    Rengan77.
    I just checked out your DXF for the chess pawn. Your profile is made up of generally individual polyline segments. This could be an issue, as the direction could be random, and possibly the odd gap in the profile. Much safer to join all segments required into 1 continuous polyline (No gaps, and all going the same way) as the Follow polyline functions do not correct direction.
    Also split the big arc at 0 and 90 degrees to remove the unwanted part, and to allow Ezilathe to truncate the cut as required.
    Parted it off for you as well. The head will still show a slight undercut from the tool radius and 11 deg lead angle. you would be better off with a sharp knife tool with no rad and 0 lead angle.
    Attached Files Attached Files
  1. Lathe programming
    By mcm1961 in forum Haas Lathes
    Last Post: 08-20-2021, 02:35 PM
  2. Cnc Lathe Programming
    By millmonkey1 in forum Employment Opportunity
    Last Post: 02-04-2011, 01:17 PM
  3. Programming a bar puller in X2 on a lathe
    By bob1112 in forum Mastercam
    Last Post: 01-06-2009, 05:05 PM
  4. lathe programming learning ?
    By pit202 in forum Haas Lathes
    Last Post: 11-23-2007, 02:41 PM
