584,833 active members*
5,515 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > They arrived , Gerber Dimension 200 e times 2 .
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Feb 2014
    94
    Re: They arrived , Gerber Dimension 200 e times 2 .
    A few pics of the system test . You tell me if this is looking pretty darn good so far .
    Attachment 275794Attachment 275796Attachment 275798Attachment 275800
  2. #22
    Feb 2014
    94
    Electronics ( motors ) are up and running . Slightly tuned till they are mounted back on the machine . Still no major glitches so far . Need to calibrate for the size of lead screws Gerber has on them yet .
    Should have at the end of it all 2 spare Gerber control boxes , that I don't see myself ever using .
  3. #23
    Feb 2014
    94
    One machine put back together and motors mounted , tuned better and on the stand . Screws calibrated and velocities i am okay with . Some cable management to do and grease all the screws , directions need to all be reversed as per the Mach jog screen settings , but those vids I know I have seen . Just forgot to save the link . New bearings should be shopped for next week . Since the gantry height is only 2.25 inches off the table , plenty of room to cut the extension side plates 1/2 to 5/8 thick alum . New riser blocks under the existing gantry only needs four holes drilled on each and longer bolts for them . Figure adding just another 3 inches to height for now for a 5.25 clearance , some table material clamps to go also . Coming together quite well . Still have to do a spindle / router mount too ,
    All of you have helped through your threads with issues you had to deal with , Thanks sincerely .
    Machine 2 should be no issue .
  4. #24
    Feb 2014
    94
    Did the first test cuts today and the machine with the swap out of electronics has had a few weird happenings but all in all I am pleased . ( that motor hum that some have had through a previous post when in idle mode ) Attachment 276522Click image for larger version.
  5. #25
    Feb 2014
    94
    It has been close to 2 weeks and all is well with the electronics swap out . Getting closer to the spindle choice to be completed , but for the hand trimmer used it hasn't given any problems as of yet and I think it is coming close to being on it's last legs . No loss in steps and circles are circles when cut . Click image for larger version.
    When the spindle choice is made , then should be looking at doing some aluminium .
  6. #26
    Feb 2014
    94
    G540 , cables and motors arrived today to swap over the second machine . Will be nice to get it going as well .
  7. #27
    Feb 2014
    94
  8. #28
    Oct 2019
    Hey Kru82. Would you have any extra components you would like to get rid of? I have recently come into possession of one but I’m missing items needed to get this thing operational.
  9. #29
    Dec 2019
    Quote Originally Posted by Gisseppi View Post
    If you're still looking for parts, I have a full working controller for a Dimension 200 that I no longer need.
  10. #30
    Jul 2017
    347
    [Hi
    Need advice...my neighbor wants to sell me a 2o yr old gerber dimension 200 with engtaving head and router and about 25 cutters.....in working cond.for 600$... is that a good deal?...
    OTE=Kru82;1675256]Y axis continued , pics . The compression spring end of lead screw is inset roughly 1 3/8 inch or 34 mm
    Attachment 274482Attachment 274484Attachment 274486Attachment 274488Attachment 274490Attachment 274492Attachment 274494Attachment 274496Attachment 274500Attachment 274502[/QUOTE]
  11. #31
    Been reading your thread. I’m trying to move a currently running Gerber Dimension 200 and Acrstation from a 20 year old Win95 machine to something more current and would love to know the hardware you used.
  12. #32
    Feb 2006
    11
    Hello Jason,
    I saw your post about your D200.
    I found a way to use a newer PC with the existing electronics and motors.
    Did you ever retrofit new controls etc ?
    I'm in Massachusetts.
    https://www.youtube.com/watch?v=m-cAdBB9148
    Sincerely,
    Mark
Page 2 of 2 12
  1. G & M Code on a Gerber Dimension 200
    By quaturbo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-16-2012, 01:15 AM
  2. My Gerber Dimension 200 router needs help!
    By markrobertsigns in forum Want To Buy...Need help!
    Last Post: 04-02-2010, 12:16 AM
  3. Looking for Gerber Dimension 200
    By gio666 in forum Community Club House
    Last Post: 06-01-2008, 03:32 PM
  4. Looking to buy a gerber dimension 200
    By gio666 in forum Canadian Club House
    Last Post: 05-27-2008, 08:39 PM
  5. Gerber Dimension 200
    By teemac in forum Gerber
    Last Post: 04-22-2007, 05:30 AM
