584,817 active members*
4,899 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Nobody knows? Big Problem with 20/50 Failure 119
    Mar 2015
    5
    Hi to all!
    I do have a 20/50 which is working for usual
    But does have the problem since about 1 week
    So the miller is in the workpiece with about 2900rpm and 0.2mm- Then just goes down to 0.035mm, then stops and shows alarm 119.
    Only in Automatic mode is the problem. Tried to change some boards but without luck (didn´t changed all boards).
    When alarm comes there is no failure on spindle drive or axis amplifier.
    Sometimes the machine also is running 3 hours without any failure.
    Maybe someone does know what up with the machine.
    Thanks a lot!
    Aug 2007
    44
    Lightbulb Re: Nobody knows? Big Problem with 20/50 Failure 119
    This alarm 119
    ENGLISH = STOP PROX MALFUNCTION
    GERMAN= MESS.HALT SENSOR ES DEFEKT
    Please check PRS-38,39 on the tool length measure
    output check H07-6 and H07-7
  1. Replies: 13
    Last Post: 05-04-2022, 07:03 PM
  2. Structural Failure Problem
    By albasha79 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-05-2015, 10:20 PM
  3. Problem - Pendant Link Failure
    By Heinster in forum Cincinnati CNC
    Last Post: 08-20-2013, 05:02 AM
  4. MDI / RAP failure
    By s&swelding in forum Cincinnati CNC
    Last Post: 04-30-2010, 07:24 PM
  5. Replies: 0
    Last Post: 01-27-2009, 07:18 PM
