585,754 active members*
3,874 visitors online*
    Hydraulic Linear Actuator
    I'vebeen tasked with retrofitting a horizontal bending machine. It currently runsoff 17 year old DC servo system. The bending jaws are actuated by 30 tonhydraulic ram that is given a variable stopping point provided by a mechanicalswitch that rides on a DC servo driven ball screw. This is a jumble of parts,it's truly amazing it ever worked. Would I be able to use something along thelines of a servo valve driven by a PLC to set various stopping points for thecylinder? Would it be repeatable and accurate? Thank you for your time.
    24220
    Re: Hydraulic Linear Actuator
    Machines such as Pines benders use both servo motor/ball screw combo and Hydraulic servo valves.
    But both methods use a servo loop with encoders.
    Using an arbitrary stop point using a PLC would not be very precise.
    At the very least you may have to use a analogue module and encoder input module in the PLC, but it is open as to whether this will be accurate enough.
    Al.
    Albert E.
    Jul 2007
    1602
    Does it really need to be re-engineered or just retrofitted? The current concept of operations as you describe it appears sound (as evidenced by the 17 years they got out of it so far). Perhaps the wisest approach would be to modernize what is there. You might be able to reduce the parts count some but what they have there is pretty hard to beat. If I understand it correctly there is no coupling between the servo part and the actual operation of the machine once the switch is positioned. If that is the case, then even if the servo blows up, they could still do a run of parts by manually positioning the switch. If you do something that ties the positioning with the operation of the press, then you potentially take that away from them.
    bob
    You make an excellent point Bob, thank you.
  1. Hydraulic Actuator Leak?
    By BadTad in forum Uncategorised MetalWorking Machines
    Last Post: 06-03-2014, 07:34 PM
  2. Replies: 0
    Last Post: 07-27-2013, 06:29 AM
  3. MLA Mini-Actuator: PBC Linear’s Solution to Bio-Tech Linear Motion
    By Pacific Bearing in forum News Announcements
    Last Post: 05-07-2009, 07:35 PM
  4. PBC Linear Expands the PL Series by adding the PLB Linear Actuator
    Last Post: 03-06-2009, 09:58 PM
  5. Linear actuator!
    By JBV in forum Mechanical Calculations/Engineering Design
    Last Post: 10-21-2005, 07:12 PM
