585,994 active members*
4,834 visitors online*
    Nov 2012
    Step setting changing on its own??
    I am not sure if it is me touching the "Step" button on accident and not noticing it on the jog shuttle or if PathPilot is changing it on me, but after one bit, one probe tip and a couple unexpected moves I am beginning to wonder. I usually always use the step in the .0001 increment but a few times when I went to step close to a part it was somehow in the .1 increment which I only noticed after the fact. I even had been using it to shave .005-007 (5 to 8 revolutions in the .0001 step mode) off a part multiple times did a z move to check the part moved back and the next step was .1??? It happened 4-5 times throughout a 5 hour session of conversational and manual part making. Will keep an eye on it and let you know if I figure it out otherwise if you have noticed or figured it out or have the same problem feel free to chime in!!
    Installing the 1.6 update today maybe it has been taken care of?
    PCNC 770 Series 3
    Jun 2014
    1780
    Re: Step setting changing on its own??
    I had the same problem, turned out that I was hitting the step button inadvertently, since I have been watching that I havent had any unexpected changes.....
    mike sr
  1. Need help with changing power setting in Moshidraw
    By artisan322 in forum Laser Control Software
    Last Post: 03-24-2015, 02:02 AM
  2. Need Help setting/changing parameters
    By richieharris in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-20-2012, 06:33 PM
  3. Z axi problem with step changing
    By normunds_a in forum Mach Mill
    Last Post: 10-26-2009, 11:26 AM
  4. Changing S/N setting 26 to cancel alarm 144
    By robard in forum Haas Mills
    Last Post: 03-14-2009, 05:32 PM
  5. Accel Step Rate Hz Setting
    By Sanghera in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-30-2005, 01:10 PM
