584,817 active members*
4,810 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Sending NC programs to SEICOS lambda 10L (hitachi seiki tf-25)
Results 1 to 13 of 13
    Mar 2015
    10
    Question Sending NC programs to SEICOS lambda 10L (hitachi seiki tf-25)
    I'm unable to send NC Programs from a PC to SEICOS lambda 10L (hitachi seiki tf-25 cnc lathe), using the RS232 cable.
    If anyone shares the procedure, its would be a life saver. I wonder if there might be a dedicated program for this purpose from hitachi seiki.
    I've tried every possible option with CIMCO, and still can't do it.
    Dec 2009
    539
    Re: Sending NC programs to SEICOS lambda 10L (hitachi seiki tf-25)
    Hello,
    were you ever able to send previously? Or did it just stop working? Did this machine ever lose its information/parameters?
    John
    Mar 2015
    10
    Hi John,
    I don't know the correct procedure of sending codes for this machine, I do according to my experience but I'm unable to send or receive codes, if you know the procedure and the correct settings, Please let me know. (using rs232 cable)
    Mar 2015
    10
    John, Do you know the parameters related to rs232 connection for seicos lamda 10L? maybe I should check those. As I read in this thread, baud rates and settings for the ports are stored as a parameter. Im not sure what the settings in the user interface in the input screen, are for?
    Dec 2009
    539
    Hello,
    they are parameters 5000-5199, that should get you set to send/receive
    John
    Aug 2010
    156
    the Lambda should have a setting page to access all your send /recieve parameters.
    I do not know your cable configuration. it could be a cts/rts or xon/xoff issue
    does your cable work on any other machines? if so match the cts & xon settings.
    if i recal you have RS232 port 1 & port 2 on your setting page try them both
    Do you get any alarms?
    Mar 2015
    10
    Here's the list of parameters 5000 to 5200 on my machine:
    View image: 1
    View image: 2
    View image: 3
    However I dont know the correct settings for them, my RS232 cable works fine with another korean CNC lathe that we have. should I change the connections on my RS232 cable? if you can possibly point out how and the correct configuration for the cable, I can do it on my own or find someone who can do it according to the diagrams you provide.
    Thanks in advance.
    Cable configuration:
    View image: cable config
    Input/output during send operation:
    View image: during recieve
    seiki DON (I have no idea what SEIKI DON is)
    http://postimg.org/image/ceuqyewwh/
    Mar 2015
    10
    I tried to set the parameters according to the maual today (Thanks Jeff), used Parameter 20, 21 to set rs232 as the comunication means, set the baud rates, stop beats, etc both using the settings page and parameters page, but i still get either "line is busy" or "Framing error"
    Dec 2009
    539
    Hello, are you still having trouble sending / receiving programs
    John
    Mar 2015
    10
    John,I still have problems, I got the documents for the correct configuration of RS232 cable, and the settings from hitachi seiki support. but can't send programs to the machine, i guess its a defective motherboard. I'm looking for a brand new motherboard, if you have in stock, please send a private message.
    Dec 2009
    539
    Sent you a PM, take a look
    John
    Dec 2013
    Hello! I'm currently having this same problem. It is very frustrating. What was the solution, if any? Thanks for your help!
    Mark
    Dec 2009
    539
    Mark,
    so you have a TF25 w/ lamda 10? What is the alarm you are getting? Have you set the communication parameters to you parameter sheets? Did it used to work previously?
  1. Hitachi Seiki VM40 with Seicos MII
    By sting007 in forum Hitachi Seikis
    Last Post: 01-28-2015, 12:22 PM
  2. Hitachi Seiki VM40 seicos 2
    By bevins in forum Hitachi Seikis
    Last Post: 05-08-2013, 04:06 AM
  3. Hitachi Seiki VM50 Seicos Lambda- memory issue
    By robert0707 in forum Mori Seiki Mills
    Last Post: 01-25-2011, 07:44 PM
  4. Hitachi Seiki Seicos
    By Enda in forum Fanuc
    Last Post: 12-15-2009, 06:14 PM
  5. hitachi Seiki VK45 with Seicos II
    By Dancy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-13-2007, 09:26 PM
