585,748 active members*
3,673 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > puma 8hc-3a with sub-spindel
    I need help for following problems in working with machine
    1- I can not have C axis to rotate
    2- I can recall B axis
    thanks for anyone who can help me.
    Jan 2008
    78
    Re: puma 8hc-3a with sub-spindel
    Quote Originally Posted by NOJANTAJ View Post
    Is your control a Fanuc 15TF? If so, we might be able to help. Could you supply your OP1-OP40 parameters to me? We have lost some of the Option Parameters (OP1-OP40) and are not able to get our machine up. If we can get it up, we might be able with your C axis problems.
    Cheers,
    Steve
    Aug 2012
    65
    Good day guys. Got a Puma 8HC-3A. Lost all parameters. Tried getting from local agents, but no luck. Started sorting it out and are now stuck in spindle parameters. If i start spindle, only loadmeter goes high, but no movement then alarms 31. Does anyone have a back up parameters and diagnostics? Fanuc O-T machine serial no 3P08 0126.Machine was operational, but battery never checked.
    Aug 2012
    65
    Quote Originally Posted by jacof View Post
    The machine is a PUMA 8HC-3A. The control is Fanuc o-T with Alpha series servo drives.
    Machine serial number is :3P080124
    Any help is much appreciated thank you.
  1. help for puma 8hc-3a with sub spindel
    By nojantaj in forum Questions or Problems
    Last Post: 03-29-2015, 12:37 PM
  2. Fres spindel
    By nitrov in forum Norwegian
    Last Post: 10-04-2014, 09:46 PM
  3. PUMA 2000sy VS PUMA 2100sy
    By GreggC in forum Daewoo/Doosan
    Last Post: 10-03-2013, 11:51 AM
  4. spindel stopping mid job
    By jessec in forum SprutCAM
    Last Post: 12-07-2009, 06:04 PM
