586,009 active members*
4,811 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > K2CNC > K2-TC9 servos motor z axis braking options?
    Mar 2015
    5
    I'm looking for a brake to add to my z axis motor to keep the head from dropping when the machine is powered off. I bought my motor from K2 cnc but I haven't been able to get on their site to contact them. After a little research, it appears that K2 CNC has gone out of business... I haven't been able to find a brake using the numbers on the motor. Does any one know of a braking system that will work for K2-TC9 servos motor? Is there another part number I should be searching for? I couldn't find any other numbers off the motor itself or the reciept... maybe even a spec print? Any insight on this would be a great help thanks!
    Re: K2-TC9 servos motor z axis braking options?
    Just an FYI I have direct replacement TC9 k2 servo motors from the same manufacture that k2 used CNCRepair - Home
  1. What size servos, gear reduction options, etc?
    By MrArmyAnt in forum Servo Motors / Drives
    Last Post: 06-11-2010, 06:33 PM
  2. BEMF and stepper motor reversing as a braking method?
    By Oldmanandhistoy in forum Stepper Motors / Drives
    Last Post: 11-09-2006, 07:37 PM
  3. dc motor braking
    By najnielkp in forum CNC Machine Related Electronics
    Last Post: 10-07-2005, 05:14 PM
