585,737 active members*
4,674 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Cant find router mounts for the KRMx01
Results 1 to 12 of 12
    Unhappy Cant find router mounts for the KRMx01
    Hello again
    I am having a heck of a time finding router mounts. K2CNC is of no help, (are they still in business? I can't even get the site to load), as is anywhere else I have searched been fruitless in locating a mount for any one of the 3 routers listed in the KRMx01 book. Is it going to be an issue of buying any fixed base router and having a machine shop make a mount and hope for the best? Buy a spindle w/mount and controller? I don't know.
    Does anyone have any recommendations, suggestions? I want what is best for the KRMx01 CNC machine. I found all three routers listed in the build book, on ebay, but can't find the necessary mounts anywhere.
    While searching on ebay I found some air cooled and water cooled 400W to 2.2kW spindles with mounts and PWM controllers that are supposed to work with Mach3 or a potentiometer if you don't want Mach3 to control the speed . Can something like these be used? Here is a link to one of the 400 watt spindles: CNC 400W Spindle Motor ER11 Mach3 PWM Speed Controller Mount Engraving Set | eBay
    I really don't know if the 400W has enough umph. I don't think I want to mess with anything water cooled as it sound like a real pain. I need help please.
    I am very new to all of this and really don't know what I need. All I know is I can't find what the book calls for and that's why I am here. You guys on this forum have been a great help so far and I have faith you will steer me in the right direction.
    Thanks in advance for all of the help...
    Re: Cant find router mounts for the KRMx01
    Awesome! Which router do you recommend? The Bosch 1617 or the Hitachi M12VC? I believe the Hitachi is the one used in the build and is a little less expensive...
    I've never used either, but I think the Bosch is a little better. Ton's of people use the Hitachi, though.
    Thank you very much for your help! I think I will go with the Hitachi as that is the one that was used in the book.
    Mar 2006
    115
    Don't know what is going on with k2cnc.com, but they do have a facebook page. Maybe you can contact them that way. I done a whois on the domain and it does not expire till 2018. When doing an nslookup I get a server error. So either they no longer have a web page, or their provider is down.
    Joe
    Aug 2010
    686
    K2CNC can be problematic these days.
    Try Velox CNC, they sell the same mounts.
    veloxcncrouters
    Here is the link to the Hitachi mount
    http://veloxcnc.com/proddetail.asp?prod=RM-Hitachi
    Author of: The KRMx01 CNC Books, The KRMx02 CNC Books, The KRmc01 CNC Milling Machine Books, and Building the HANS Electric Gear Clock. All available at www.kronosrobotics.com
    Aug 2010
    686
    Others have reported that the CNCRouter.com mounts work as well. In any case post your results back so others can benefit,
    May 2016
    14
    I'm building a KRMx01 and here's the mount that I ordered for mine today: VeloxCNC (forum removed the link to it)
    They sent me the STEP file and by the measurements there, it should bolt right up to the KRMx01 Z Plate.
    Aug 2010
    686
    Thanks for the info. Post some pics when you get a chance.
    May 2016
    14
    Quote Originally Posted by msimpson99 View Post
    Will do. I think I will just start a new thread and post pics of my build there. I didn't keep an excellent record like Joe at MyHeap.com did, but his site was my inspiration for building the KRMx01 as my first build.
    Aug 2010
    686
    I can confirm that the CNCRouterParts mounts work just fine with the KRMx01. Purchase just the mount (minus the adapter plate) and it will bolt directly to the KRMx01 Z-plate. I have a write up for the KRMx02 here:
    CNC Router Parts Router Mounts — Kronos Robotics
  1. Router Mounts
    By Jkountz in forum Momus Design CNC plans
    Last Post: 11-16-2013, 01:04 PM
  2. failed router mounts ...
    By Claytonc in forum Hobby Discussion
    Last Post: 07-30-2011, 04:39 PM
  3. Hitachi Router Mounts
    By jjacstcy in forum DIY CNC Router Table Machines
    Last Post: 02-02-2011, 04:37 AM
  4. router mounts design
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 08-16-2004, 02:36 AM
