585,930 active members*
3,815 visitors online*
Results 1 to 7 of 7
    Dec 2004
    174
    Master XY380 from Desay
    The Master xy380 from Desay ($569 shipped with 3 extra blades) arrived about a week after i ordered in two large boxes delivered intact by Fed Ex. The machine was in a double layered box and the stand was in the other. The flexistarter software was easy to set up and worked by just following the directions. CNC router skills do carryover to this machine in software and material set up. I have cut vinyl for a number of signs. The Flexistarter software in somewhat limited but is quite usable in conjunction with coreldraw. There are apparently direct cutting drivers for Coreldraw but I haven't tried to set up for this. I got a new registerable copy of Coredraw v12 from ebay for $65, this software includes a very good trace program that will be very usefull for my cnc routers.
    Anyway the machine works great, is kind of loud, is very fast, cuts very accurately, and was very inexpensive compared to a Roland or other name brand machine.
    Assembly took about an hour, you really need a philips screwdriver
    (in picture) that holds the screw to assemble. All the frame screws must be inserted through the outer to the inner wall of the frame extrusions.
    Attached Thumbnails Attached Thumbnails DSCF0071.JPG   DSCF0052.JPG   DSCF0049.JPG   DSCF0054.JPG
    6855
    I have the same one and LOVE it, the only thing I don't like about it is that it is a little noisy.
    Dec 2006
    16
    I've had a blast with mine. It cuts vinyl, sandblasting mask, t-shirt heat transfers, etc. And scores magnets and lleather! OK, it's probably not a big deal, but scoring leather for tooling is way faster than tracing a design by hand. I got the cutter to cut glass acid etching stencils faster than tracing them by hand, and now can make perfectly matching glass and leather mediums.
    It's been 14 months that I've played with mine, and have been so busy that almost none of the projects it was bought for was done. Other things to try or that people want keep cropping up.
    Feb 2007
    master xy-380
    i am in desperate need of the user manual or any kind of instructions or drivers that came with this plotter. i recently inherited one with out any knowledge or instructions. can any one help?
    Dec 2006
    16
    You bet, just email me at [email protected] and I can email you a pdf manual for the XY-380P. Pictures of mine are at the bottom of the page www.foxesfarm.com and you can look to make sure it's the one you've got.
    May 2015
    Re: Master XY380 from Desay
    Quote Originally Posted by cncadmin View Post
    HELLO THERE I AM DESPERATE TO FIND THE DESAY MASTER X-380P PLOTTER DRIVERS PLEASE HELP IF YOU CAN. THANK YOU
    May 2015
    HELLO THERE I AM DESPERATE TO PUT THE DESAY MASTER X-380P PLOTTER TO WORK AND COMMUNICATE WITH MY COMPUTER I NEED THE CORRECT DRIVERS PLEASE HELP IF YOU CAN. THANK YOU
  1. Desay Master XY-380p
    By timcole421 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 05-04-2009, 05:39 AM
  2. Master-Cam
    By johnsguns1 in forum Mastercam
    Last Post: 04-08-2008, 09:29 PM
  3. master cam x
    By frankg521 in forum Machines running Mach Software
    Last Post: 10-31-2007, 01:10 PM
  4. CNC Master
    By Paul in OK in forum Benchtop Machines
    Last Post: 11-15-2006, 08:13 PM
  5. How well does master cam
    By johnm in forum Mastercam
    Last Post: 06-02-2003, 05:06 AM
