I see ebay has lots of tachometers, i found a bunch that are 30 dollors, digital screen, optical sensor. I should just buy one, there cheap, they don't need to be calibrated. One of the main reasons i was trying to stay away from the freq-to-volt is because i know my knowledge on that topic sucks so bad that i know even if i tried i would screw up something somewhere, thats why i was trying to avoid that setup, for what its worth i'll prolly end up just buying something decent off ebay, that way i don't need to worrie if the circuit i build has all the bugs worked out, if i did all the calculations 100 percent perfect. Yes i understand you won't know till you do it, and you can't learn unless you start messing around with them, but this isn't the project where i am willing to take a risk cause the last thing i need is my bearings going, i and trying to save them as best i can and i don't want to risk them cause i'm not good with math and especially electronics. I'll definitly try and spend time on the freq-to-volt setup on another project a little less extreme like maybe.... my gokart engine!! i could save this project for my gokart engine, that will work. That way my rpm problem is simply over no worries no risks just taken care of. Although if i doo see something that i think i could build for less then 30 bucks i'll definitly give it a shot, the only thing i got to lose is my engine at high speeds afterall.
