Hi i'm building a very special jet turbine and its bearings are designed for max 120,000rpm. I've looked all over google for homemade tachometer circuits. I could use either 2 magnets for a magnetic rpm circuit or i could use a light probe? Does any1 know of a simple rpm tachometer i could build. Any circuit schematics or info would be great. I'm not the best with electronics but i've built a couple of small little circuit boards from parts from radio shack and simple designs off internet sites so i have some expirence with circuits. It would need atleast 4 digits in its screen and it could be digital, led, i just need anything that will do the job. I can play around with different designs and make them work as long as the electronics are taking care of. Whats have you guys found out with your engines?? Anybody have anything?? Thanks :cheers:
<!-- / message -->
