Hello.
Today I´ve made an 18 degree square to test if the wire is making an accurate angle.
The two corners of the top were ok but the two bottom corners were very deformed. When I made a dry run to check if the wire was hitting the nozzles , I realized that it was hitting only the upper nozzle because the wire IS NOT centered with the nozzle... When I press "wire guide open" it goes to the center of the nozzle , but when the guide is closed it is not centered (the wire goes in Y+ direction). Is this normal ?!
