As the title describes, I've found this forum because of the latest issue with my Trotec laser engraver. I was using the laser when it shut down completely without warning mid-cut.
I immediately checked the main fuses and then proceeded to check every fuse I could without turning up anything. The next steps in testing were to verify if any power was going to the pair of PSU on the back of the machine.
When reading the poles for what I assume should be 110v my meter reads no change when power is turned on. The connections are visible in this photo as well.
Some observations that may be totally useless but anyways... There are two relays in the photo below. The lower one triggers immediately when the power switch is toggled, the upper relay seems to have a slight delay before switching over with a louder click. It's at this time that the machine emits a very high 20khz(?) buzzing/ringing noise from this area of the board.
I've attached some other photos of the machine below as well. My next steps are to remove the board from the machine an begin to manually test the relays and resistors - we haven't got much else to go on. Any and all suggestions are appreciated as the local technicians are reluctant to come work on a 15 year old machine.
