585,987 active members*
4,315 visitors online*
Results 1 to 12 of 12
    LC6090 Won't Turn on
    So here is the situation. I have an LC6090 at 100W of power. I've been running it for just over a year now.
    Two days ago I was running it as normal. Turned it off and went home for the night. The next morning it would not turn on.
    There is no power flowing to any part of the machine. I turn the key, nothing happens anywhere.
    I checked the fuse thats attached to the power in plug, it seemed fine, HOWEVER I had a spare fuse that I threw in there just to check. Still nothing.
    I checked the breaker. Reset it even. Nothing.
    I followed some directions online and tried the Test button on the power supply. Nothing lit up. (The fan on the power supply is also not turning.)
    I replaced the power cable with a different cable. Nothing.
    Can anyone lend a hand in figuring out whats wrong? Is it the power supply?
    Mar 2015
    40
    Re: LC6090 Won't Turn on
    there are two power supplies in there, the laser high voltage one for the tube and the 24V for the controller and motors. since neither is working i would start the troubleshooting by using multimeter to see if AC reaches them at all. and from your description i have a feeling it doesn't ,despite the fact you chaged fuse.
    Mar 2015
    79
    This may sound silly, but plug a lamp or radio into the outlet and check for power.
    I checked for power with the output, it's running just fine. I have a computer hooked up to the same outlet.
    I tried following these directions. Nothing.
    https://www.youtube.com/watch?v=7a2TvdkNn48
    Where is the other power supply located?
    Jul 2014
    147
    Quote Originally Posted by BrownDogGadgets View Post
    Dear Sir,
    If you can send me more pcitures details that will help us to solve your problem.
    Best&Rgds
    Apple
    EETO Machinery Co., Ltd
    Office 1401, Building B3, Wanda Plaza, Economic & Technology Development Zone, Wuhan, China
    Tel:400-027-1897 Fax:027-84618501
    Mobile: +86-15527861820(Whatsapp Available)
    Web:www.eetomachinery.com
    E-Mail:[email protected]
    Skype: lovelx0226
    I don't know what good pictures would do.
    One weird thing is that power is also not going to the Chiller or the Compressor, which leads me to believe that it's NOT the power supply but something else. The fuse is fine (and even replaced just to be safe).
    I'm at a complete loss.
    Feb 2012
    387
    Dear ,
    Here is the video to help to test the whole machine without electricity , hope it can help you
    https://www.youtube.com/watch?v=ez8D...ature=youtu.be
    Best Regards
    Lucy Lee G.WEIKE LASER
    [email protected]
    Jul 2014
    147
    Well done guys!
    Quote Originally Posted by gweikelaser View Post
    Dear ,
    Best Regards
    Oct 2010
    24
    He had a similar problem with our machine before. Legacy Lasers came out and put in a new key switch for us and everything came back on.
    Could be that or the Estop
    TK McKnight
    800 Series 60W from www.legacylasers.com
    Mar 2015
    40
    so did you test AC reaching the two power supplies with a multimeter?
    Oddly enough it turned out to be the on/off switch. The switch had two sets of terminals on it, so we switched the wires to the second set and now it's working fine. Just insanely weird.
    I appreciate all the help and comments. Thank you very much.
    Now back to laser cutting...
    May 2016
    Hi BrownDogGadgets,
    Having the same problems (no lights on power supply or other outlet from the machine). I'm wondering what on/off switch you're referring to. Is it the one in the grey box on the back of the machine, key hole on/off, or emergency stop on/off.
    Thanks!
  1. G.Weike LC6090 - My experience
    By loopingfred in forum G.Weike Laser
    Last Post: 04-28-2021, 08:05 AM
  2. UPDATE - 4 years with my WKLaser LC6090
    By FlyGuy007 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-28-2011, 09:27 PM
  3. Wk Laser LC6090 and Lasercut 5.3
    By wooddr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-28-2011, 08:49 AM
  4. LK Laser LC6090
    Last Post: 05-22-2010, 10:30 AM
  5. Help Needed With WKLaser LC6090
    By Garrettind in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-10-2010, 01:53 PM
