585,973 active members*
4,182 visitors online*
    Aug 2004
    107
    Trying to swap slave axis
    I am trying to swap the A-Axis which is slaved to the X-Axis, changing it to B-Axis. I have transferred the settings from A-Axis to B-Axis , changed the A-Axis slaved to X-Axis to B-Axis and restarted the program....will not turn. I am doing this so I can have the A-Axis for the indexer so i can see the visual in Mach3.
    I have a pmdx-126 board without the smooth stepper. I have my additional Gecko hooked up to J6 on the pmdx-126 board, pin 1 for step and pin 14 for direction. Do I need to hook up anything to common on the G201X Gecko drive? Any help would be great I am lost.
    Oct 2010
    54
    Re: Trying to swap slave axis
    In Mach3's "general settings" did you uncheck "b-axis angular"?
    Feb 2004
    1086
    You can't use pins 1 and 14 from port 1 -- these are already used for the relays on the PMDX-126 board. You need to use pins 16 and 17, or else disable the relays (using the dip switches on the PMDX-126), but I'd personally want to keep these. The common terminal needs to be tied to PCGnd for a G201x.
    Best regards,
    Ahren
    CNCRouterParts
  1. Dual Y Axis Slave A Axis Homing Problems
    By guy2b1 in forum Calibration / Measurement
    Last Post: 03-03-2012, 11:06 PM
  2. CNC Fusion X2 kit - possible to swap over X-axis?
    By Steoh in forum Benchtop Machines
    Last Post: 02-18-2011, 01:15 AM
  3. Swap axis feature..possible with Fanuc 6MB..?
    By Leblondmakino in forum Fanuc
    Last Post: 12-26-2009, 04:35 AM
  4. Replies: 8
    Last Post: 10-29-2009, 02:09 PM
  5. Spindle motor swap, or servo swap?
    By Chuck Reamer in forum Tormach Personal CNC Mill
    Last Post: 10-09-2007, 06:54 AM
