585,981 active members*
4,151 visitors online*
Page 2 of 2 12
Results 21 to 36 of 36
  1. #21
    Re: FrankenC CNC Pro 4'x8' NEMA 34 build
    Quote Originally Posted by jueston View Post
    where did you get your spindle? and what are the specs on it?
    2.2kWt 220v CNCRP.
    I would suggest people to call CNCRP because it appears that they have a lot more goodies on the shelves than they do on the website.
  2. #22
    3/8" Onsrud compression bit, 280ipm at 8500rpm
  3. #23
  4. #24
    Did a bit of profiling last night. Legs for a piece of furniture.
    100 ipm at 15 000 rpm. .25 rough depth.
    Attachment 283054Attachment 283056Attachment 283058Attachment 283060
    Looking in to flip milling next. It'll involve horizontal finishing with ball mill. Mmmmmm so exciting!
    Has anyone incorporated an air blower in to a dust shroud to help clear chips out of the cut?
  5. #25
    Apr 2015
    82
    if by flip milling you mean 2 sided cutting, its a little bit of an adventure in itself. it took me 5 or 6 tries to get 2 sided cutting to line up perfectly.
    i used the pin method, cutting 2 .25 holes on opposite ends of the project and then 2 holes in the spoil board and then flipping it over and inserting a pin to line them up. i found that you want to have the pin so tight into the hole that you have to use a light tap with a hammer to get it to seat, but not so tight that you have to really whack it, because then your crushing one side of the hole, and the piece will not be centered anymore.
    when you cut both sides, every tiny problem is doubled, so if your X and Y axis are not exactly 90 degrees, it will be obvious. if your spindle is not 90 degrees to the spoil board, it will show.
    i don't have a CNC right now, but i've always thought, if i go shopping for a used one, my test will be to cut out a 12 by 12 square in 3/4 MDF going half way through both sides, it really is a great test of exactly how tuned the machine is.
    i have never worried about the chips gathering inside the cut, i figured it doesn't cause much of an issue for the next time the router goes over that spot.
    my CNC had a router instead of a spindle, how would you describe the noise level from your spindle?
  6. #26
    It's louder than my Festool 2HP router and quieter than my old Porter Cable 3.5HP router.
  7. #27
    some .126" brass profiling for the customer.
  8. #28
    Apr 2015
    82
    what feed rate and depth of cut did you use for that brass?
    i have not cut any metal yet on my cncrp
  9. #29
    2 flute carbide 30 degree helix. 10 000 rpm, 10 ipm, 0.025 depth of cut.
    this is 355 brass alloy.
  10. #30
  11. #31
    Jan 2015
    194
    Since I have a home theater subwoofer business and just ordered a 5x10 CNCRP Pro, that makes me happy. What feed rate and what bit are you using? Anew is that 3/4" Baltic Birch plywood? Is that a Kent dust shoe or did you make your own? Thanks for sharing.
  12. #32
    I've done a bit more adjustments on the X-rail and squared the spindle again.
    Put a new spoil board and resurfaced it. Learned how to "face" 17" wide boards, using surfacing bit. Actually very handy because my jointer is only 12" wide.
    I used more connectors between spoil-board and aluminum framing and it's flatter and sturdier.
    Here I am cutting chair parts. 3/8" spiral down bit was zeroed on the spoil-board and then raised 0.0001. The tip of the bit did cut through the mahogany but not through the spoil board. It was so close however that it impregnated MDF with Mahogany dust. Pretty cool!
    dgage,
    1/4 compression from Whiteside. 150ipm (round about) and 12000 rpm
    Kent dust shoe. (really like it)
    BTW, I am one of the Parts Express newly selected Design Team members.
    (1/4" not 3/4" corrected the size of the compression bit)
  13. #33
    Jan 2015
    194
    Thanks for the info R-Carpenter. And congrats on being a Parts Express Design Team member!
    David
  14. #34
    playing with Window Movie maker
  15. #35
    Jan 2015
    194
    Very cool. Thanks for sharing!
  16. #36
    Here's another vid. Finished design for a mid sized line array speaker for Parts Express.
Page 2 of 2 12
  1. CRP4848 Nema 34 Build
    By nlancaster in forum Avid CNC
    Last Post: 12-03-2016, 02:06 AM
  2. PRO4848, NEMA 34 Build, Electronics Help
    By CYoung in forum Avid CNC
    Last Post: 04-27-2015, 05:18 PM
  3. Replies: 7
    Last Post: 01-10-2015, 01:40 PM
  4. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  5. New Build. Nema 23's and 3-axis Univelop Board
    By HerbalHaze in forum Stepper Motors / Drives
    Last Post: 10-06-2008, 11:00 PM
