585,880 active members*
7,904 visitors online*
Page 1 of 2 12
Results 1 to 20 of 36
    FrankenC CNC Pro 4'x8' NEMA 34 build
    Hi guys and gals.
    I am half way in to the build at this point.
    First thing is, I am very happy with the service and delivery times of CNCRP. They ship then they say and the parts are well packed. I only had one minor damage on a gantry aluminum bar but it was nothing a file couldn't take out in 3 swipes.
    Attachment 276578
    The router is build using 1940s machine stands. My shop is located in Brooklyn Navy Yard so it's a bit of charismatic aspect. Reusing the old tech for the new tech.
    Attachment 276580
    Custom frame was welded in my friends shop so the bases can be bolted to each other.
    Re: FrankenC CNC Pro 4'x8' NEMA 34 build
    Attachment 276584
    After the base and the frame were more or less leveled, 2 1.5" sheets of MDF were bolted to the frame. All grade 7 hardware.
    Attachment 276586
    Attachment 276588
    Attachment 276592
    Now I am about to start putting motors and cabling on.
    Feb 2007
    711
    Very nice, I love those legs. You plan on painting them?
    Quote Originally Posted by alan_3301 View Post
    Thanks!
    One of this days........... then I have free time.
    Question. Did anyone ever look for an alternative to a .5"x1" guide rails that are not split and perfectly straight? So far, this is the only questionable part in the build. Not complaining, just thinking out loud.
    Nov 2009
    90
    Quote Originally Posted by R-Carpenter View Post
    Thanks!
    Yup, I agree, that is the only part that bothered me as well, but I think with some careful tuning it will be a non-issue. I would be willing to pay extra if CNCRP would sell the 4896 kit with full length aluminum side rails and full length hardened steel rails, but I'm sure those wouldn't be cheap to ship!
    Nov 2011
    73
    Thanks!
    All I could suggest is trying to source some 112" long versions locally. I just installed mine today and haven't looked to see if it's possible.
    If you paint those legs, they should be Battleship Grey! Stay true to the Navy Yard!
    -Eric
    Battleship Grey sounds good! ........ Some day.
    I am going to pick up this thing McMaster-Carr next week. As I go through my shop, I realize, I don't have any reference precision straight edge.
    Started the motor install.
    Nov 2009
    90
    Good choice on picking up a straight edge. However I think a 6 or 8 ft level would be as accurate as that, but cheaper and probably available locally. The levels, like that straight edge, are shown to have an accuracy of 0.005", however that number alone isn't really enough to tell you how accurate the edge is (Is that .0005" of error over the entire length (Extremely accurate, so unlikely)? .0005" accurate on the width at a given point (which says nothing about straightness), .0005" over 12"? ). Both will be subpar to a machinist straight edge or parallel, but at a fraction of the cost and probably good enough for what we need on these routers.
    McMaster-Carr
    The level may provide more utility for other projects I would imagine. 8 ft levels typically run around $100
    Aug 2006
    39
    Those legs look awesome. That new cnc should make quick work of some line arrays. Haha. How long did it take you to get your machine from when you ordered?
    Quote Originally Posted by talonosi View Post
    McMaster-Carr
    You may have a point there. I got the staright edge today and the edge is not straight at all. Called McMaster to find out if the one I got is a dud or this is the way they are.
    Quote Originally Posted by dan3676 View Post
    I ordered the parts in 2 courses. Took about 3 weeks each time from the time the order was placed to the time it arrived. The aluminum rails came in fairly quick. I think within a week.
    Yeah, line arrays are no holiday to be cutting with hand held router.
    So, I've send the McMaster layout straight edge back and have been lurking on ebay.
    Starrett. 70" near perfect shape. I took it over to friend who owns Mitutoyo Black Granite Surface Plate aaaand, very happy with results. The Starrett is 0.0005 per ft of lenght so I think this should be more then enough to straighten out the guides.
    Nov 2009
    90
    Awesome, if you don't mind me asking, what did you pay for it?
    $200 + $24 s&h
    Nov 2009
    90
    $200 + $24 s&h
    Nice, great buy. I may have to keep an eye out for one.
    A friend of mine came over to help today and we spend about 4 hours shimming X rail (one side) and got them to be within 0.002 over 8ft. Not too bad. Casehardened steel rails presented some issues. Tomorrow, hopefully I can finish the other side and start squaring of the Y and the Z.
    Just want to extend a special THANKS! to Cory at CNCRP for helping me quickly troubleshoot issues with Mach3 set up. The issues were due to my inexperience.
    Thanks Cory!
    Nov 2011
    73
    Thanks Cory!
    They know there stuff that is for sure. Cory and Ahren have handled everything from sales, tech support, and every little question I had during the buildout. I am a satisfied customer!
    Apr 2015
    82
    where did you get your spindle? and what are the specs on it?
Page 1 of 2 12
  1. CRP4848 Nema 34 Build
    By nlancaster in forum Avid CNC
    Last Post: 12-03-2016, 02:06 AM
  2. PRO4848, NEMA 34 Build, Electronics Help
    By CYoung in forum Avid CNC
    Last Post: 04-27-2015, 05:18 PM
  3. Replies: 7
    Last Post: 01-10-2015, 01:40 PM
  4. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  5. New Build. Nema 23's and 3-axis Univelop Board
    By HerbalHaze in forum Stepper Motors / Drives
    Last Post: 10-06-2008, 11:00 PM
